Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-18-2007, 09:59 AM
surferfletch surferfletch is offline
"Dad. The engine's smoking real bad."
Those are the first words I heard this Sunday morning. She took the truck down to the local pool for her lifeguard/first aid training and called me from there. I'm sure her teenage friends were hysterical about an impending fire. I ran to NAPA and got the intake and valve cover gaskets with the plug tube o-rings for $50. The Victor Rienz valve cover gaskets look more substantial than the Felpro gaskets I got at Advance. Maybe this is why they are leaking a year and a half later? It needs to cool, I need breakfast, then I'll dive in. I imagine it decided to smoke a little more today as it's been cold down here (40 at night). All of the lifeguards were huddled up at the edge of the pool in their sweatshirts and sweatpants. I bet they are looking forward to getting wet later!
1997 Isuzu Rodeo LS 3.2L V6 SOHC 4L-30E Dueler Alenzas 4x2
1997 TJ Sport 4.0L D35 rear 5 spd 31" Dayton Timberline ATs
1996 VW Jetta GLS 2.0L 5 spd
Old 02-18-2007, 02:11 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: "Dad. The engine's smoking real bad."
So it is leaking oil then?
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 02-18-2007, 04:37 PM
It was leaking. I have the new one on now. I forgot what a PITA it is to get a couple of those valve cover bolts and one of the EGR bolts out/in. There is still some smoke being produced as it burns off the exhaust.
It was a little unsettling for the engine to run rough on the first startup, but I hadn't plugged the #4 coil all the way in.
What other potential leaks are there on the driver's side at the back of the engine? Did I get the only possible culprit? The passenger side is showing just a little oil in a couple of spots. I'll change it if I get really bored some night.
Old 02-18-2007, 05:00 PM
Looks like I got it. The wife took it to get some groceries, and when she got back there was no smoke and that pleasant burning oil smell was gone. I don't think I'll ever have that rusting frame problem with the coating of 10W-30 there.
Old 02-18-2007, 05:06 PM
It was October of '05 that I changed the gaskets last.
Old 02-18-2007, 07:28 PM
And I guess I can bring the intake gaskets back. I didn't take the plenum off.
Old 02-19-2007, 06:17 PM
highlandlake highlandlake is offline
Doh! I should have done that trick 3 years ago!
'65 Chevy Malibu SS
'06 Pontiac Vibe (a dead deer fits nicely in the back)
'04 Ford Escape
GMC S-15 4WD
'57 Chevy 210 post sedan
'51 Ford F2 pickup
Recently gone but not forgotten - 68 Chevelle, '97 Rodeo V6 4WD.
Old 02-19-2007, 06:26 PM
No leak today. I wonder how long it'll last...
Old 02-25-2007, 08:14 PM
Well, I got back under the truck tonight because it still seems to be leaking from the rear camshaft tower area. It looks like there is a plate covering the rear camshaft tower, held on by 2 bolts, and it is leaking from the base of that plate. It is not leaking from the base of the towers at the point where you are supposed to apply a bead of RTV, which I did when changing the valve cover gasket. Something under that plate seems to be leaking. It does say to apply a bead of RTV where the front and rear camshaft tower meets the head. It would be a bummer if it were leaking there. Thanks for any help!
Old 02-25-2007, 10:04 PM
Ramblin Fever Ramblin Fever is offline
Did you replace your camshaft seals at the time of your timing belt swap?
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 02-25-2007, 10:15 PM
At the first timing belt swap, I had the shop do the seals. I did not do them when I did the timing belt the second time. Is there a rear camshaft seal back there under the cover? If so, I'm sure it's never been changed.
Old 02-25-2007, 10:18 PM
http://www.car-stuff.com/cs_auto/mmp...s446e1ddd94b0c
Is this what I need?
They are rear camshaft plugs. Under the cover? Nobody at planetisuzoo.com has mentioned these plugs either.
Old 02-26-2007, 12:35 AM
Seems a couple of guys on the Zoo have seen this before, including trooperbc. I'll let you know how the repair goes...
Old 02-26-2007, 01:56 PM
Getting the part is always a blast.
Advance: "You'll have to get me a part # cause I wouldn't even know where to begin to look for it."
NAPA: "It's listed with a number, but I can't get it."
Honda dealer: "It's $14 per cap. I can have it overnighted for another $19. That's about $50. Otherwise it'll be here a week from Wednesday."
One online supplier had it for about $15.
Three calls to St. Charles and I have the correct parts on the way.
If anyone has done this before, please let me know if the rear camshaft plug is the only part I need for this job. I understand there is also a very cheap (63 cents) cap that goes somewhere back there as well, and I don't know if I need it. Also, I hope this can be done without removing the valve cover again. It looks as though there is no need to remove it. I'm going out now to see what I can see after taking the plate off the back tower. Thanks.
Old 02-26-2007, 08:04 PM
I doubt you'd need to remove your valve covers - my mechanic did mine at the time of timing belt replacement, and I know for a fact my valve covers haven't been off since 2001.
I do believe Trooperbc has excellent knowledge and is a very informative poster, we can definitely benefit from his knowlege. I believe he has experienced this before....maybe??
I honestly don't know if *both* my camshaft seals were replaced, I'm thinking maybe just the front. I'll double check with my mechanic tomorrow; he's working on a check engine light issue on my Yota now.
1997 3.2L V6 Rodeo
