Where do I add clutch fluid?
The clutch has a lot of freeplay and engages very low to the floor so I think I'm out of fluid (or I need a new clutch O_o).
Anyone know where I add fluid? Clutch fluid is just brake fluid, right? |
Re: Where do I add clutch fluid?
They run off the same resevoir. If you have brakes then you should have clutch. I had a clutch go low on a different car I had and it was a rusted release arm in the bellhousing.
Does it make a difference if you pump the clutch pedal? Worn pivot points in the clutch pedal and clutch fork can cause the problem you described.
http://www.autozone.com/servlet/UiBr...3d8013c989.jsp |
