Old 02-17-2007, 11:00 PM
metallica21156's Avatar
metallica21156 metallica21156 is offline
rebuilding the abs
has anyone ever rebuilt thier abs? i might have to fix mine and i was woundering how hard it was to take apart and put back together.
95 jimmy. Vortec V6. 4.3 liter CPI. ,2.5" catco cat, 2.5" cat back with flowmaster muffler split rear., 40 street series, 2 12" audiobahns in custom box,K&N CPI intake system.
71 Mustang coupe- project car. stock 302 with Cobra intake, holley 650dp, afco racing radiator, headman headers, msd distributor, 2.5" from the headers.C4 tranny with shift kit, Mach 1 body lay out.
90 cav, 2.2 tbi, gas getter.
99 chevy s10 zr2, 6" lift, duel exhaust. 5 speed.
Old 02-18-2007, 10:06 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: rebuilding the abs
Are you asking about the ABS unit or just the regular brake parts on it?
The ABS unit is a non overhaul idem.
What is it doing or not doing or what is the problem?
MT
Old 02-18-2007, 11:03 AM
the abs unit isn't working. and i tested the one connector that they call the big 3 way connector which has a black wire which is ground and a red wire which is 12v all the time and a pink one that goes back to the computer. with the engine running i got nothing going back to the computer on the pink wire while its pluged in and once i unpluged it i ohemed out where the two wires plug in at and it shows its open. i've got some other things two test. i wanted to know about rebuilding it because i remember someone one here saying they did one time but i don't remember anymore then that.
Old 02-18-2007, 12:08 PM
MT-2500's Avatar
AF - Advisor
They are not a rebuilder idem.
I would check for ABS codes to find out where the problem is.
Post back code no. and maybe someone can help.
MT
