Old 02-17-2007, 06:41 PM
3000-GTO's Avatar
3000-GTO 3000-GTO is offline
Speaker Wire
My driver side door speaker is not working. I know for a fact it is the wire in the door jam that connects to the door wiring harness that is the cause of this. The problem is I don't know which wire that is so I was hoping someone could describe to me which wire it is. Thanks.
Here is a picture of which part of the wiring harness I am talking about.
http://i159.photobucket.com/albums/t...ngharness1.jpg
Old 02-17-2007, 07:29 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Speaker Wire
how do you know that the wire in the door jam is the cause?
an easy way is to remove the door panel, locate the speaker wires. they will be specific colors. then simply find the same colored wires in the door jam.
i bet this site will have the answer to the wire color: http://www.3saudiofaq.com/.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 02-17-2007, 10:08 PM
3000-GTO's Avatar
Re: Speaker Wire
Thanks for the help I managed to figure it out.
