Go Back   Automotive Forums Car Chat > Pontiac > Sunbird/J2000/2000 Sunbird
Old 02-17-2007, 06:31 PM
|WYG|SS |WYG|SS is offline
Not Starting
My 1991 subird le 2.0L will not start or even try to start, not even a clicking noise for when trying to start. i had just put on new starter, i have gotten eletrical schematics and it shows the ignition wire running to the park/ neutral switch on transmission. i have power to alternator and stuff . its just that when i go to start the car it is not getting any power through purple/ignition wire. when i got my new head gasket on and it would try starting but then slip so when i went to remove old starter i forgott to disconnect the battery cabble (cause i thought i had it out of car), and when i went to take the battery cabble part off on the starter just a big spark flashed in front of me cause i touched the rachet to mettal. I get all lights and other stuff on in car. my dad and i jumped the ignition bolt to battery bolt on starter and car tried starting. do you guys think i could have shorted something out in the ecm? cause the electrical scematics show the purple wire running to the brake switch and then to the ecm (i think) and then to the switch on the transmission.
Old 03-03-2007, 04:54 AM
Re: Not Starting
just so you guys know this is restated and i added more stuff about my car not starting.
Old 03-03-2007, 06:03 AM
hottrod64 hottrod64 is offline
Re: Not Starting
Have you tryed to start it in neutral ? I am thinking you shorted out your neutral safety switch
Old 03-03-2007, 07:05 AM
Scrapper Scrapper is offline
AF Premium User
Re: Not Starting
are both cables good and clean? or you might have blown fuse or you may have burnt a fusable link down by starter but always take neg. cable of first...
Old 03-03-2007, 01:35 PM
Re: Not Starting
i had went under mmy dash also and ran resistance/power through the purple wire and i am getting voltage throurgh it. i have tried it in neutral and nothing. i have looked at all fuses and none blown. all the fuseable links are good and all wire's are clean.
Old 03-05-2007, 07:03 AM
Re: Not Starting
it is a bad neutral safty switch.
