Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 02-17-2007, 06:20 PM
Gandalph Gandalph is offline
1989 Instrument cluster
Has anyone ever had the problem of half of the cluster going out???I still have power to the three leads but no gauge reaction on the left hand side. Tachometer, Oil Pressure and Temperature gauges all show zero!! Could it be the circuit board or some other problem??? It's a 1989 yoda SR5 Deluxe with 22re, deluxe cab long bed. Does anyone have suggestions??? Thanks in advance!
Old 02-19-2007, 10:39 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: 1989 Instrument cluster
A bad ground has been known to cause similar symptoms.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 07-14-2007, 09:03 AM
Can someone let me know where exactly is the ground for the instrument cluster??? I've redone the grounds to the engine block I could find but the left side of the cluster still is not working. Are there two grounds to the cluster, one for each side of it??? Will a faulty ground to the ignitor cause this problem??? Thanks in advance
Old 07-17-2007, 08:26 PM
fourwd1's Avatar
AF -Advisor
Hit your browser's Back button, look at the first thread (factory service manuals) and click on it.
89 4Runner - stock
