Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 02-17-2007, 02:20 PM
Gems Gems is offline
Fans always running
My radiator fans are always running and the engine temp. gauge never moves up... After turning the engine off the fans continue running for a couple of minutes and then shut off... I'm thinking the coolant temp. sensor has gone bad??
Go Mark Martin!
Old 02-17-2007, 02:35 PM
Re: Fans always running
I got a P0128 code from my code reader...
Go Mark Martin!
Old 02-17-2007, 03:03 PM
crazy Jim's Avatar
crazy Jim crazy Jim is offline
with the P0128 code some people are claiming that replacing the thermostat has fixed the issue. I have not had any personal experience with this code though. Fans should run anytime the AC is on.
master airframe mech/shadetree auto mech/30+ years experience
current vehicles:
'02 Impala LS 3.8L
'02 Trans Am WS6 LS1 6spd
'99 Grand Am SE 3.4L
'71 Cutlass SX 455/TH400
'04 YZ450F
'07 Kona Garbonzo (dowwnhill mountain bike)
Old 02-17-2007, 03:32 PM
And now the car won't start... An old problem... It fires, starts, stumbles and dies... This morning it ran perfect...
Go Mark Martin!
Old 02-18-2007, 10:54 AM
I replaced the ECT and thermostat... Car started and ran... But the fans start running right away and stay running after turning the car off... The temp gauge still never gets off the bottom... And I still read a P0128 code from my code reader... I buzzed the short length of harness from the ECT to the connector on top of the LIM.. It buzzed good... What now??
Go Mark Martin!
Old 02-18-2007, 08:45 PM
hawkeye1956 hawkeye1956 is offline
Send a message via AIM to hawkeye1956
Have you tried resetting the computer since changing the thermostat? My wifes car had the same symptoms last winter as you described. I would disconnect the battery overnight, although an hour is probably long enough, then everything would be fine for a couple of weeks before it would act up again. Eventually, the weather got warmer and the problem went away. I replaced the thermostat and flushed the cooling system over the summer. This winter, I have not seen the problem reoccur at all. In my case, the thermostat seemed to be the long term fix. Good luck!!
Old 02-18-2007, 08:54 PM
No, I have not tried resetting the computer... I will try that tomorrow morning... Thanks...
Any other thoughts or ideas from anyone are appreciated...
Go Mark Martin!
Old 02-20-2007, 05:00 PM
OK, problem seems to be fixed... I first tried to clear the DTC by disconnecting the battery for about 90 minutes... That did not clear the code... So I used my Actron DTC scanner to clear the code... Once I did that everything is working properly now... I just don't know why disconnecting the battery for 90 minutes did not clear the code but the erase function on the scan tool did...
Go Mark Martin!
Old 02-20-2007, 11:35 PM
wiretowire wiretowire is offline
Ahhh...the old Temp Gauge issue. Well, we have a 2001 Impala V6 with the 3.4 - 3400 engine. At 50k miles we got the low coolant warning light. Yet the system was full. I looked at the radiator cap to find the sludge of dex cool death. So I read the blogs and it leads to getting a new cap - Stant model. This works for a while. Then the fans stay on after the car shuts off and the temp gauge doesn't budge causing check engine light to come on. After scanning with OBDII, I get the ol 0128 code - Temp not up to spec. No crap...I could tell that with the gauge not coming up at all. This happend last December (2005). So....take it to a dealer and they scan (for $65) and it says its a coolant sensor. When changing the sensor, they claim to see a coolant leak in the upper intake. Any of this sound familiar? I had to laugh when I found this site. So dealer wants $700 to $800 to replace this (hell, to put in the $25 sensor it was $125). I get the gasket fixed (not at the dealer - but would love to know if GM still covers this after 36000 and 3 years, as I saw someone said they would for a one time fix). So after the coolant sensor, gasket, radiator cap...all was fine. That is...until it cold again this year. Same thing happened this winter. Fans staying on, gauge not budging, this time...at least no leak in the gasket. Go back to the dealer, of course its past their 12kmile 12 month warranty and simply ask for the sensor. Its now $29, but the doofus I talk to now says, change the thermostat, not the sensor. So I buy the thermostat and sensor.
So far so good. After changing the thermostat and since I was in there, changed the sensor as well, and the gauge actually got above 160 degrees and is in the middle of the gauge now.
Forgot to mention that its a cold weather issue. Gauge would come up fine when ambient temp was greater than 30 or 40, but when it got lower, temp gauge stopped working, fans came on, even after car engine was shut off...which all leads to thermostat. Here's why - if the thermostat is faulty, it won't allow circulation past the coolant/temp sensor an inch away. The temp sensor can burn out if fluid is not going past it. This sensor, when it gets hot, tells the computer its too hot - so kick the fans on. Even though engines not overheating or even hot, the sensor doesn't know this since its flow is restricted. So...this should answer why the fans come on... as well as the check engine light - P0128 should be the code.
Adios!
Old 02-21-2007, 08:00 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Disconnecting the battery doesn't always clear the codes on OBD-II cars. Normally, they will require the use of a scan tool to do so. The PCM will not recogize the new parts until the codes are cleared, so that is why the car continued to act up.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 02-21-2007, 06:37 PM
OK, here it goes again.. After 1 day of the temp gauge working correctly and the fans turning on when only they should it's messed up again today... The fans again are constantly running and the temp gauge is stuck on the bottom... And the P0128 code has come back... This is after installing a new ECT sensor and a new 180 degree t'stat a few months ago...I erased the code and the fans are off again for now... What the heck is going on???
Go Mark Martin!
Old 02-22-2007, 02:29 PM
richtazz's Avatar
you may have a grounded/shorted wire harness between the ECT and the PCM.
Old 02-22-2007, 05:40 PM
Thanks, I'll check for a short... I'm also going to put in a new t'stat on the off-chance that the one currently installed is defective and stuck open, or partially open...
Go Mark Martin!
Old 03-04-2007, 07:17 PM
josephk300 josephk300 is offline
Gems - I've been through this too, and for my 01 Impala LS, the fix was putting in the best quality 195 thermo I could get (I believe it was a Gates), and also replacing the temp sensor (I'm not sure what an ECT is - is that the temp sensor?) Previously, I had this problem and only had been replacing the sensor, but the fan running and temp gage dropping to 0 would come back. Pulled the PCM fuse to reset, and the problem has been gone since it was done in Nov 2006.
Old 03-04-2007, 08:34 PM
Yup... I kind of have 2 threads going here on the same topic... Read my "Stuck Open Thermostat" thread here... I think I have the problem resolved, just like you have described... (2001 LS here also)
Go Mark Martin!
