Old 02-17-2007, 09:45 AM
dugg365 dugg365 is offline
new parts no start
'93 jeep cherokee start and run... after new: plugs, wires, cap, rotor, and battery the engine will not do anything. all fuses are good all electronics in the cockpit work as do exterior electrical. when the ignition switch is engaged the temp. gauge sweeps all the way to the right. did i do someting wrong?
Old 02-17-2007, 10:10 AM
bthust bthust is offline
Re: new parts no start
check starter relay
Old 02-19-2007, 09:01 AM
brainyass's Avatar
brainyass brainyass is offline
check ignition coil
Old 02-19-2007, 09:18 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
If it ran fine before you did your work, go back and check all the connections that you worked on, and all the connections nearby.
It could be as simple as the coil wire being unattached (an error I admit to doing several times)
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 02-23-2007, 03:33 AM
hundahunta hundahunta is offline
bad battery connetion or starter
