Go Back   Automotive Forums Car Chat > Honda > Classifieds
Classifieds This is the place to buy and sell your Honda parts.
Old 02-17-2007, 03:45 AM
kpeters0929 kpeters0929 is offline
FS TONS of the best parts you can buy! Wisconsin!
For sale... Everything is in Mint tip-top shape. Less then 2000-2500 miles on everything. I purchased all brand new back in october and only got to drive my crx less then a month before the weather changed and these parts sat ever since. I'm going a different route for next year and i have no use for these things. Please don't pm me asking for trades because i don't need anything. Only thing i may be willing to work a deal out with is a gt42R turbo or bigger...... k here you go....
Fluidyne half sized radiator for 92-00 Civic's. Perfect working condition, comes with slim fan-$220
Endyn breather kit-$120
MSD Pro Billet distributor setp. Comes with dizzy, magnacore wires, coil, and ignition module. The dizzy is obd2 but i also have a MSD obd2-obd1 conversion harness as well. Best ignition setup you can buy!! -$350 for everything.
GM 3 bar map sensor with pigtail-$30
Hondata S300 installed on USDM p30 ecu. Install was done by a Hondata dealer. Comes with software etc. This has it all, boost options etc. $600
Exedy twin disc clutch for ALL 92+ B-series transmissions. Will work on cable or hydrolic trannies (only difference is you use different throw out bearings obviously) Has roughly 2000-2500miles on it. Mint condition, this will handle as much power as you throw at it! $800 Add 19mm ARP flywheel bolts for $20 extra!
BRAND NEW Worldwide Alternator for obd0-obd1 b-series. Lifetime warranty as well from advanced auto parts. Also has aem pulley on it. $90
Aeromotive A1000 injected bypass fuel regulator. Summit part #AEI-13101 Comes with -8an fitting in to connect to your fuel rail and -6an elbow fitting out. Remember when you buy these regulators new they don't come with the fttings for them-$120
Mr. Gasket "the beast" high performance starter. eliminates heat soak. mazworkxracesupply sells them on here for $150 Shipped. -$100 for it (remember everything i am selling on here has less then 2000-2500 miles on it!! All basically brand new!)
RC 1000CC peak and hold injectors. Again 2000-2500miles on them tops! Basically brand new. Add a resistor box for $5 for them. $220
Mr. Gasket 68mm throttle body, comes with map sensor and gsr throttle bracket. You can use this on ALL b-series.... it has both holes on the throttle rotor so you can pull the cable with the gsr throttle bracket or from the other way with the bracket on the intake manifold. Mazworx also sells these on h-t -$200
Selling my COMPLETE turbo kit!! Everything was purchased brand new, made 550WHP with this setup and has less then 2000-2500miles on it!! Setup is...
Garrett GT35R Turbo .63a/r 4 bolt exhaust flange
aem 4" filter
3" downpipe (has tiny tiny dent about the size of a nickel on the bottom, nothing major, not cracked etc. won't affect anything)
Custom made ramhorn turbo manifold
tial 44mm v-band wastegate with 13lb blue spring
2 1/2" beautiful intercooler piping all tig welded. Bends are mandrel. Stainless steel.
Tial 50mm bov
Turbo has -6an russell fittings for coolant lines, as well as the -an lines to run it. Also has -4an oil inlet fitting with restricter and -10 Functiion7 outlet fitting with -10an steel braided line to connect to oil pan.
All turbo boots are included with all t-bolt clamps
Johnny racecar intercooler 3" thick
Pipes are gauranteed to fit like stock in 88-91 Civic/Crx's. I do believe you should be able to get them to fit in 92-95 civic's as well and possible teg's and ek's with slight modification.
$2000 takes it all!!!! Don't waste your $ on a greddy kit when you can get the best one $ can buy for less!
TurboXS high-performance dual stage boost controller-$160
Autometer C2 mechanical boost gauge-$30
Autometer C2 mechanical oil pressure gauge with russells -4an stainless line with fittings-$45
BFG drag radials 225/50/15's. Have life left in them-$100 for both
88-91 Civic/Crx new upper control arms with ingalls adjustable ball joints already installed. Included is another set of NEW spc adjustable ball joints as well. $100 for everything
Ingalls rear camber kit i believe will work on 88-00 Civic/Crx/integra's Part #38920-$70
ac autotechnic sandwich adapter for honda/acura's Comes with fittings to attach your oil lines to head/turbo/gauge. Lines are extra-$40
polished antifreeze catch can-$25
rywire obd0-obd1 conversion harness-$75
dc sports dual bend shifter for 88-00 honda/acura's-$30
PLX M-300 Wideband. Only used it after my car was dynoed. Less then 800miles on it-$220
Python 871xp paging alarm system. Also included are power door locks-$175
REAL CF spark plug cover for b-series vtec heads-$35
JDM CTR cams, have normal wear, no scratches on lobes-$300 for both
Taylor battery box-$50
Anyone interested just pm me. Located in Milwaukee, WI. Depending where your from i'd be willing to meet up. I have a bunch of other stuff that i will post fs later, but this is most of the good stuff.
Old 02-17-2007, 01:15 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: FS TONS of the best parts you can buy! Wisconsin!
bump for the best grouping of parts i've seen in a long time on this site.
I might take you up on that GM3bar map
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 02-22-2007, 11:42 PM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
hey still got the spark plug cover? i got money ready!
-tony-
2000 honda s2000
Old 02-23-2007, 02:44 AM
BoostedLSVTEC BoostedLSVTEC is offline
hey man, i live in wisconsin (racine/kenosha area) im intersted in ur parts. whats ur # or u can call me at 502-641-1378. have money and ready to meet up to pick up parts.
