Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 2nd Gen 00-05
Old 02-16-2007, 11:42 PM
tch1717 tch1717 is offline
replacing rear springs
let me know what you guys think, i have a '00 LX, and a buddy that had a old neon (1st gen.), said that to reduce the "rake" in the 2nd generation, was to install 1st gen springs in the rear of my car, i don't really want to lower the car, just "flatten"it out, apperently the old neon springs had a diferent spring rate, or where shorter, or whatever, but he swears this will work. any thoughts ??
Old 02-17-2007, 07:05 AM
Matts01ES Matts01ES is offline
Re: replacing rear springs
If u put first gen springs on ur second gen it will lower the car. They did have a lower rate. I WOULDNT do it. What is it u want with the car? Smoother ride? what?
Sum on the Sum Side!
Old 02-17-2007, 12:09 PM
alls i'm looking at doing is lowering the rear of the car (seeing as it sits higher than the frt), i would like to leave the stock springs in the frt and just replace the rears so to give the frt and rear about the same ride height
Old 03-02-2007, 12:18 AM
95,2001neon 95,2001neon is offline
I also have an issue with the ride height. I would like to bring the front and rear to even with each other. Suggestions?
