94 Cav flashing headlights
sometimes at night if I have my high beams on for an extended amount of time -the headlights will start flashing and then they will go off.
I had to drive home holding the high beam switch on. |
Re: 94 Cav flashing headlights
that sounds like a safety feature.. its incase u accidently forget your high beams on they shut off for you automatically
I agree. Why would you be driving on high beams anyway??
A SAFETY FEATURE where your headlights go out because the highbeams have been on too long ............LOL . Come on people get out of the city for a while. Harley sounds like you may have headlight switch or related lighting relay going for a crap. Do a forum search here you may find info you are looking for in regards to replacement
Life Is A Highway ,Enjoy The Ride
his headlights don't go out, his highbeams go out... read the original post
if the switch or relay was bad they wouldn't come back on when he holds the highbeam switch on |
one other thing I have discovered in reading post again "I had to drive home holding the highbeam switch on". what was happenning here is that the person was activating the "flash to pass " mode in the headlight switch which also leads me to beleive headlight switch is going bad . But that`s just my opinion.
Muff
Yea I have been having problems with my low beams lately.....when i switch it to hi beam, the switch seems hard to click....and sometime when i start the car and flick my lights on, low beams wont come on until i play with the lever a bit......I dont know what it is but i need to find out soon.....
high beam for to long as fear of sitting on the side of road with no lights |
If I remember a 1994 correctly, your car has a headlight switch on the dash and a high beam switch when you pull back on the turn signal stick, right?
If this is correct, did the dealership replace the headlight switch or the turn signal switch? Without a wiring diagram in front of me I don't know if power to the low beams goes through the high beam switch, but it could. If I'm on the right track with this, I recommend you replace the turn signal switch - especially if it feels physically hard to move. |
