Old 10-02-2002, 06:09 PM
n2it4sq n2it4sq is offline
error code 16
Ok I need a little help. I keep getting an error code 16 on my 90 dx hatch. I have reset the ecu and get no check engine light. I checked at the local parts store today and they want 110 bucks for rebuilt injectors. Assuming that is the real problem here.
I really don't want to put any additional money in the engine. I finally found a shop I trust to swap a zc in for me. Lastly what is the going rate(s) out there for an engine swap including headers, intake and exhaust. Just wanna make sure I am not getting burned on the deal.
Is it ever truly finished?!!!!!!
Old 10-03-2002, 10:12 AM
JoshDM JoshDM is offline
nsit4square, injector problems
first make sure the connectors are good on the injectors, and the ground is good on the thermostat housing.
if you have 2 injectors first check to see if they are ticking, with a stethoscope tf you have one, if they are, pull the plug on each injector and measure the resistance between the 2 terminals on the injector, if it is not in .6-1.6 ohms that injector is bad, if it is than connect your voltmeter positive to the main injector's yel/blk wire and the negative to a good ground. turn the ignition switch on. is there battery voltage for two seconds? if not you have a bad spot in the yel/blk wire. if there is check the resistance of the auxilliary injector by the two terminals, if the resistance is not 6-10 ohms, replace the injector, if it does, take the voltmeter like before, between the yel/blk wire and a good ground and check for battery voltage for two seconds, if not, you have ashort in the yel/blk wire, if it does than take your voltmeter and connect the positive to the yel wire of the auxuluary injector and negative to body ground. is there approx 10V? if not than check for a short in the yel auxiliary wire. if yes than measure the voltage between the main injectors red wire. is it approx. 10v? if yes it may be your computer, if no than check for a short in the red wire between main injector and ecu.
good luck!
SiKiller
Old 10-03-2002, 10:34 AM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
Wow, i'm impressed. Did you read that out of a manual? Sounds just like they put it in the books at my work(dealership)
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 10-03-2002, 10:41 AM
91zc 91zc is offline
It is the troubleshooting flowchart out of the helms manual put into words. Good job and good info
91 civic 4dr
b16a
14.8@94
Old 10-03-2002, 10:57 AM
yeah, I work parts at a honda dealership. too bad I don't have a scanner or i would just send in the picture and diagrams instead of typing if all that shit out, but i'm here to help and usually bored so I don't mind that much.
SiKiller
Old 10-03-2002, 10:59 AM
www.quickhonda.net has the 1991 crx Si service manual online.
91 civic 4dr
b16a
14.8@94
Old 10-03-2002, 11:35 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
JoshDM, you mind if i add that info to the how-to's section at 4thgenerationcivic.com? i actually get that questions a lot. i know how to do it (lord knows how many i've been through this nighmare of a year) but i can never find the right words to explain it
ami
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 10-03-2002, 12:11 PM
thanks 91zc for the manual info
LadyNRedSi of course you can use it, I plagurised it myself anyways.:bonghitte
SiKiller
Old 10-03-2002, 02:44 PM
Thanks Joshdm I will give it a try this weekend!
