Old 10-02-2002, 04:51 PM
purespeed187 purespeed187 is offline
Exclamation B16a into 88-91 crx ??????
hey i am planning on buying a crx and i intend on bolting in a b16a motor what i want to know is what is the cheapest way to so this.
should i buy a si or buy the cheaper model and pay a few extra hundred for the transplant. plus how much does it usually cost to get the engine and to get it proffesionally installed.
Old 10-02-2002, 08:54 PM
Tominos Tominos is offline
just buy the cheapest crx. i think you will need wiring harness anyway, the b16a doesn't seem to be a straight bolt in for the crx. i am pretty sure that you need a special mount kit. b16a first generation should run about 1150+ at hondamotorsonline.com, and for install, local shops here charge about 800.
Old 10-04-2002, 04:21 PM
Fishcat37's Avatar
Fishcat37 Fishcat37 is offline
Send a message via AIM to Fishcat37
I would recommend against getting a DX CRX however. You can still put a B16 into the DX, but since the DX is DPFI, and the B16 is a MPFI motor, you will need to convert to MPFI, and i think that you will need a whole new wiring harness. If you buy an HF or an Si, you will just need to add 4 wires plus a gound (knock, 2nd O2, VTEC solenoid, oil pressure switch) to the stock harness since both of those models came with MPFI. do a search, and you will find all the info that you ever needed to create yourself a B16 CRX.
FLINT BLACK 1990 CRX SI
Appearance Mods:
-JDM EF8 CR-X SiR Spoiler
-94/95 Integra GS-R rims
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-Skunk2 Intake Manifold
-DC Sports 4-2-1 Header
-MSD SCI-L ignition
-EXEDY Racing Clutch
Interior Mod
-'95 Integra GS-R Gauge Cluster
Former Motors - RIP:
-JDM B16A #1- Blew up due to over-revving
-JDM B16A #2 - Hydrolocked
Former Cars
'89 CRX Si - "The Bumblebee"
'94 Integra GS-R
'96 Camaro
Old 10-14-2002, 12:20 PM
TrailerParkJake TrailerParkJake is offline
Send a message via Yahoo to TrailerParkJake
hf will be the lightest of the bunch and has mpfi already, and you can pretty much transfer that harness straight across to the b16(adding the 4 others like was previously said of course) One downfall to the hx though is the fact you gotta swap out the steering knuckles for those of a civic/crx si or dx so the axles will fit in the hub, its pretty simple though.
Old 10-14-2002, 06:16 PM
teg2nd teg2nd is offline
First gen. B16A has two O2 sensors?
