Old 10-02-2002, 05:31 PM
1.5 liter 1.5 liter is offline
Send a message via Yahoo to 1.5 liter
i f**k my s**t up
i tryed to paint my bumpers and i f**ked up. im a moron. butt i painted them black, what should have i done???????
Old 10-02-2002, 06:03 PM
GTA's Avatar
GTA GTA is offline
Whee..
how did you screw them up? what went wrong? we need more details to help ya out
theres a how-to on FourthGenHatchs page
www.fourthgenhatch.com
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 10-02-2002, 07:16 PM
i didnt sand it enough. when i sprayed the paint on it, the paint wouldnt stay on the bumper. and i dont think i cleaned the bumper enough
Old 10-02-2002, 08:06 PM
mightytexn's Avatar
mightytexn mightytexn is offline
Send a message via AIM to mightytexn
Just redo it, being very careful to do everything right. If you follow the directions on www.fourthgenhatch.com you should be fine. His bumpers look real nice in the pics, and he did them himself.
I'm Jordan
My car is the ugliest one on this board
Old 10-02-2002, 08:14 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Did you use primer at all? Did you clean the surfaces properly?
Old 10-03-2002, 02:41 PM
i did everything, what fourtgen has done
ok this what ive done to them. first i took off the bumper,(the front bumper) i washed them, than drayed than washed them again with alcohol, than i wiped it down with decreaser. i dryed but and i started to sand paper them. it took about 2 hours untill i thought it was done. than i washed them again with alcohol. than dryed the bumper. i putt the bulldogg can about twice than let the bumper get dry. than i primer them with bumper primer. about 2-3 times. than i let them dry again. than i sand them again 220 grit paper. than i rince them alcohol. than let them dry and i just sprayed one part of the bumper and it came out like crap. it looked like i didnt clean them every good. so i took off the paint and i said fuck it, and i sprayed the front bumper black. and thats it. this weekend i might do it again.
did i do it right??? sounds like i didnt!!!!!
Old 10-03-2002, 02:43 PM
if u guys want i could post pics?????????
Old 10-03-2002, 03:16 PM
ci5ic's Avatar
Here's what I would do...
First, clean it good with soapy water.
Then, swab the parts you're going to paint with rubbing alcohol.
Then sand with 320 grit paper.
Then wash again with soapy water (not alcohol, which leaves a residue).
Avoid handling the bumpers with your bare hands at this point to avoid getting oils from your skin on the surfaces you want to paint.
Add a full coat of primer (use EXTREMELY light applications to avoid runs!)
Lightly sand the primer with 320 grit paper.
Add another full coat of primer.
Lightly sand again.
Then, add 3-4 coats of paint (I would probably use Krylon Interior/Exterior paint).
When dry, add 2-3 coats of clear topcoat.
Old 10-03-2002, 03:25 PM
how far do u sand it ,,,, when sanding the first time on bumper?????
Old 10-03-2002, 03:37 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
When I was primering my bumpers after putting bulldog on it in some spots I would spray it and then the primer would move away from certain spots (like it was alive) leaving weird holes with no primer. I think you really need to let the bulldog dry.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 10-03-2002, 03:40 PM
i probably should have cleaned it good. but how far do i go to sand them???
Old 10-03-2002, 03:42 PM
I sanded the whole bumper but not even that much, one good move over the bumper should do it. And I used a whole can of bulldog (or half a can for each bumper) and the paint on my bumper is still holding up good.
Old 10-03-2002, 03:50 PM
ooooo!!! crap i sand my shit to scraths!!! im a dumbass! can i still paint it even if i already painted it..... now how much should i sand it?? untill the black paint comes off??
