Old 02-16-2007, 11:13 AM
brooks6277 brooks6277 is offline
1992 LeSabre-Front End Noise
Last few days I have a loud whining (humming) sound coming from the front end which increases the faster you go and decreases the slower you go. It is not engine related because I can put the car in neutral and rev it up and there is no noise. Is this possibly transmission? The car shifts fine. Could it be C.V. joint? Are they difficult to replace. Are there any other bearings that could be gone?
Old 02-16-2007, 02:52 PM
maxwedge maxwedge is offline
A990 racer
Re: 1992 LeSabre-Front End Noise
Welcome to AF. Sounds like a ft wheel bearing, get it up in the air, safely, see if there is any play in the wheel/hub also you can run it a 20 mph or so while off the ground, again caution, and see if you can hear the noise, or let a shop do this for you.
Old 02-16-2007, 04:15 PM
Thanks, sounds like a right front wheel bearing. Looks like I will have to replace the whole unit. Is this a big job? Do I have to be concerned about ABS.
Old 02-16-2007, 08:34 PM
Bassasasin Bassasasin is offline
Its not a HUGE job... you must have the tools...
Remove the tire and allign the bolts that hold on the bearing assembly..
Also You have to take off the transaxle nut.
Remove them and encourage the slightly pressed in assembly out with a chisel or something to get it started.. Keep track of the sensor wire..
Not too bad.. There is a hyperlink to a removal of just what you need somewhere.. I cant seem to find it.
Good LUck
Bass
00' Park Ultra
94' Park Ultra
94' LeSabre
96' LeSabre
Old 02-16-2007, 08:41 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Click Here for more info.
Old 02-16-2007, 10:15 PM
Thats a good procedure.. saw one with pix.. but good just the same.
Thanks Z
Bass
00' Park Ultra
94' Park Ultra
94' LeSabre
96' LeSabre
Old 02-17-2007, 07:52 AM
Smith1000 Smith1000 is offline
I replaced one a few years ago. It was a little tougher job than I had expected. I just put in a salvaged assembly because the bearing was pressed in and it didn't look like it would come out. Also, the new bearing assembly was very expensive. Don't forget to have that large socket on hand (36mm) to remove that nut.
Old 02-17-2007, 06:41 PM
Im not sure they are pressed in..
I know the corrosion makes it very tight. I took a cold chisel and worked around it and walked it out.. The new one went in pretty easy after clean up. The bolts pulled it in.
Good Luck
Bass
00' Park Ultra
94' Park Ultra
94' LeSabre
96' LeSabre
