Old 02-15-2007, 09:57 PM
d1nonlyjv43's Avatar
d1nonlyjv43 d1nonlyjv43 is offline
Smoking Problem
91 CRX Base Model , My car is smoking and I was trying to figure out why it is. I checked my spark plugs today and when i got to the third one the plug wire dripped with oil when I took it out. Can someone tell me if I change the o- ring seals on the valve cover would that keep the oil from going into the hole. Vice Versa would it keep my car from smoking? Someone please help........
Old 02-15-2007, 11:58 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Re: Smoking Problem
Yeah, definitely a good place to start. Those spark plug o-rings will keep oil out of the plug holes. Are you leaking oil out of the valve cover too? Might be a good time to replace the valve cover gasket also.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 02-16-2007, 04:31 PM
Re: Smoking Problem
ya im leaking oil by the valve cover so im going to replace that one also. But will this keep the car from smoking or what?
Old 02-16-2007, 04:41 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: Smoking Problem
Not from smoking out of the exhaust, no. But itll keep the heat of your engine from burning the oil on top of it lol.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 02-16-2007, 04:52 PM
Re: Smoking Problem
It'll keep oil out of the spark plug holes giving you better ignition. Plus by changing the valve cover gasket you won't get any oil on the exhaust /intake manifold, cam gears, dizzy etc.
If you wanna figure out where your leaking oil internally run a compression test. It'll tell you if you have bad rings, and the overall health of the motor. Make sure you first test it dry, then wet with a teaspoon of oil.
