Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 02-15-2007, 08:57 PM
60Falcon351C 60Falcon351C is offline
351 Cleveland heads?????
Hey, does anyone know the max. valv lift that can be obtained on a set of stock 351 Cleveland 2V heads???? Thanks, and also what aftermarket heads would you reccomend If I were to replace the stocky 2V's
Mike
Old 02-16-2007, 08:51 AM
72' Stang 351 H/O's Avatar
72' Stang 351 H/O 72' Stang 351 H/O is offline
Re: 351 Cleveland heads?????
I do belive it's around .300-.400. Don't quote me on that. If you don't want to spend to much money get a 60's or 70's set of 4V heads and have them rebuilt and P&P them.
Old 02-16-2007, 11:36 AM
Thanks, I was thinking of getting an original set of 4V heads but I wasn't sure if it was worth having an original set machined or buying an aftermarket set
Old 02-17-2007, 01:34 AM
351wStang's Avatar
351wStang 351wStang is offline
Head work is not cheap, if done right anyway. Alot of times its best to just pick up a set of aftermarket heads rather than have some stockers worked up. But I'm not sure how much aftermarket there is for the clev.
1969 Cougar
357w & TKO - 475hp
Old 02-17-2007, 12:10 PM
Thats what I was thinking, I saw a set of edelbrock heads on summit for around 900 bucks
Old 02-20-2007, 02:02 PM
speedfreak's Avatar
speedfreak speedfreak is offline
Send a message via AIM to speedfreak Send a message via MSN to speedfreak
You saw ONE cylinder head for $900. A pair of assembled aftermarket Cleveland heads will be in the $1800-2200 range depending on parts options. CHI out of Australia makes aluminum 351C heads and has the longest option list on them for port, chamber, and valve sizes. They even have recast 4V iron heads.
1968 Mustang notchback Roller 302, Edelbrocks, Hookers, side-exits, RRs, Crane 2031, Duraspark, forged slugs, X-Celerator, 650DP, Fidanza FW, RAM clutch, Toploader, Comp Plus, McLeod bell, 15x7s, 1 1/8 swaybar.
1972 Ford Pinto SVO 2.3 turbo, MegaSquirt, T5, 8", etc.
'95 Honda XR600-10.5:1, 628cc, ported head, & more.
