Old 02-15-2007, 06:16 PM
killdog66 killdog66 is offline
98 blazer 4.3 no start?
98 blazer 4.3 won't start. sitting for 2 days, just turns over, fires a couple times, but won't keep firing. pump pressure ok.just changed cap, rotor plugs, feul filter. any ideas?
Old 02-15-2007, 06:18 PM
1996LTOwner 1996LTOwner is offline
Re: 98 blazer 4.3 no start?
How long ago did you replace the plugs, wires, etc.? What type of plugs did you use?
Old 02-15-2007, 06:43 PM
500mi. changed plugs, cap, etc. used bosh plugs. didn't change wires,though.
Old 02-15-2007, 07:43 PM
thadrawr's Avatar
thadrawr thadrawr is offline
Send a message via AIM to thadrawr
bad move you should keep delco plugs in a GM vehicle
1999 GMC Sierra 1500
Old 02-15-2007, 08:29 PM
DINO55's Avatar
DINO55 DINO55 is offline
Killdog66,
What was the fuel pressure reading and was the engine running or shut off when you pressure tested it???
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
Old 02-16-2007, 07:29 PM
after i changed the fuel filter, the presure when key on, motor off was 56psi. has been running at that pressure for 500mi?
Old 02-17-2007, 07:32 AM
DINO55's Avatar
FUEL PRESSURE IS IMPERATIVE
Click Me and read this......
Old 02-20-2007, 11:18 PM
thanks;
changed battery, then started. weak battery caused feul pump to not get enough pressure to manifold?
Old 02-26-2007, 04:56 AM
Glad to see you got it runnin, but those bosch plugs will foul on you. I'd replace them soon.
Old 02-27-2007, 11:40 AM
j
just, did. changed with ac's..........thanks.......
