Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-15-2007, 04:23 PM
Mobiletec Mobiletec is offline
1998 jeep grand cher 5.7 l
This jeep has abad stalling problem then i start it up again then its fine. put in gear then it stalls again can some one give me some idea what it could be thanks
Old 02-15-2007, 05:53 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: 1998 jeep grand cher 5.7 l
fix the header it says 98 5.7, the 5.7 is a HEMI, it's either a 5.2L or 5.9L...lol
When you put it in gear does it jerk then stall?
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 02-16-2007, 12:11 PM
Smile Re: 1998 jeep grand cher 5.2
sorry ya i think its 5.2. Ya it jerks then stalls. If i restart it it runs smooth for a bit if i give it gas abit it stumbles then stalls. If its in gear and i pull away it stalls or wants to stall if i let off on pedel stightly it dosn`t stall. thanks
Old 02-16-2007, 05:24 PM
sreilly77's Avatar
sreilly77 sreilly77 is offline
i had a problem exactly the way your explaining it with an old 87 chrysler new yorker i mean exactly the same problem. i could never figure it out what it was so i ended up dropping another motor in it. turned out when i was remove the old motor the idle air control valve fell off and that was the entire problem the whole time. just a thought...
Sean
Old 02-17-2007, 08:55 AM
jeepgclwj's Avatar
jeepgclwj jeepgclwj is offline
I had a similar problem as well with another vehical. I had a broken motor mount that was allowing movement which caused a wire to get grounded out everytime I gave it gas and the motor moved....I was about to give up and set it on fire but at the last minute a friend spotted the problem....
358rwhp/358rwtq with stock LS1 intake
A4 3.23 lid, pacesetter lts, ory, 243 heads, SLP LMI, ZO6 cam, BBK SSI intake, 85 mm
