Old 10-02-2002, 01:16 PM
tbk49's Avatar
tbk49 tbk49 is offline
Send a message via MSN to tbk49
Top Dead Sensor...?
Helping a friend...
"The top dead sensor on the car is gone. I have had several diffrent answers about where the sensor is.. Calgary Honda said that its in the throttle body (i call bs on that one... a TDC in the throttle body?) and i have heard in the distrubitor, and on the crank its self.. I would like to know where is located, and mabey what plug it is do i can just see if the terminals are dirty.. thanks guys"
Hes got an 89d15b engine...
blah
Old 10-02-2002, 01:23 PM
91zc 91zc is offline
It should be in the distributor.
91 civic 4dr
b16a
14.8@94
Old 10-02-2002, 01:24 PM
Fishcat37's Avatar
Fishcat37 Fishcat37 is offline
Send a message via AIM to Fishcat37
well, i've heard over bringing your pistons to Top Dead CENTER (TDC) when you're doin a valve adjustment, by rotating the crank. do you possibly mean crank angle sensor? i believe that that's in the distributor....not sure what your asking for actually...i'll just shut up now :hehe:
FLINT BLACK 1990 CRX SI
Appearance Mods:
-JDM EF8 CR-X SiR Spoiler
-94/95 Integra GS-R rims
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-Skunk2 Intake Manifold
-DC Sports 4-2-1 Header
-MSD SCI-L ignition
-EXEDY Racing Clutch
Interior Mod
-'95 Integra GS-R Gauge Cluster
Former Motors - RIP:
-JDM B16A #1- Blew up due to over-revving
-JDM B16A #2 - Hydrolocked
Former Cars
'89 CRX Si - "The Bumblebee"
'94 Integra GS-R
'96 Camaro
Old 10-02-2002, 01:31 PM
tbk49's Avatar
he also said this
ok so i am getting a code 8.. Top Dead Center sensor.. now what would cause this sensor to malfunction.. the cars timing was just set about 3000km ago when i did the water pump.. any ideas.. or do i need to buy another one and replace it?
blah
Old 10-02-2002, 05:49 PM
JoshDM JoshDM is offline
the tdc sensor is inside the distributor, you can check the continuity in the plug. if you have a round plug, check continuity between terminal
a & c, those are the two most top terminals on the distributor plug with the tab side up. it should read between 350-550 ohms, if it doesn't, than you have to get a new distributor, the tdc sensor is non-servicable.
if you have a square plug (std) than the terminals are the top middle and right (b & c), tab side up.
also check for continuity between terminals and a good known ground, if there is than it is time for a new distributor.
BUT, have you performed an engine swap?(wish I would have asked that before I typed all this stuff out).
SiKiller
Old 10-02-2002, 06:17 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Awsome answer.
Now, amswer me this if you can.
I just did a ZC swap. When I use the Integra distributor, I get a code 9, but I think the sensor is bad. So I probably need a new integra dizzy.
So I swapped in the Si distributor, and now I get a code 8, yet the Si distirbutor worked perfect on my d16 motor.
Any ideas on how to fix?
Old 10-03-2002, 08:23 AM
kbslacker w/project hooptie
there are two wires at the bottom of the plug, tab side up, they are green and blue, try switching those wires and get back to me
the SiKiller that is fast and ugly
SiKiller
Old 10-03-2002, 11:35 AM
kris's Avatar
Re: kbslacker w/project hooptie
Hmmm..... I'm not seeing those two wires. The bad thing is, the color on the wires are very faded..
Here is what I have:
Old 10-03-2002, 02:09 PM
yeah try to switch the #1 wire with the #2 wire
SiKiller
Old 10-07-2002, 11:08 AM
kaytec4door kaytec4door is offline
if ur talking about a crank angle sensor it is located on the exhast cam right next to the distributer. but the tdc sensor im not sure it may be in the distributer but i know honda distributers run on a rotor.
:smoker2:kaytec4door:smoker2:
mods done: AEM cold air intake,
ractive racing cat,
ractive axel back exhaust,
NGK plugs,
nuespeed cross-drilled rotors,
EBC the green stuff pads,
projecter headlights,
clear corners,
carbon fiber tails,
Z3 fenders,
adjustable coilovers,
Konig flatline rims with dunlop fm901 (17*7),
full complete sound system with two 10'' subs,
kenwood 600w amp,
punch cap,
pionner speakers all the way around,
full custom interior paint job,
reverse indiglo guages,
aluminum gauge bezel,
d16a6 head swap polished,
4-2-1 ceramic coated header,
:finger4: proud member of team kay tec:finger4:
Top Dead Center Sensor Kyrrah '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 14 10-05-2004 11:31 AM
Finding Top Dead Center ecko240sx Jetta/Vento/Bora 2 09-18-2004 01:27 PM
How do I set Top Dead Center (TDC)? presort Ranger | Courier 2 01-11-2004 11:47 PM
How do I set Top Dead Center (TDC)? presort Engineering/ Technical 1 12-26-2003 12:40 PM
how do i set my vavles at top dead center??? CRXsk8er '88 - '91 Civic | CRX | Wagon | Shuttlee 18 01-30-2003 04:31 PM
