Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 02-15-2007, 12:19 PM
puregold25 puregold25 is offline
95 sunfire coolant smell
my temp gage does not go up but the car is losing coolant and the inside of the car smells like coolant there are no obvious leaks inside the car though I really need some help on this please
Old 02-16-2007, 10:10 AM
hotbug1776's Avatar
hotbug1776 hotbug1776 is offline
Re: 95 sunfire coolant smell
your heater core has a slight leak, not enough to flood the interior, but enough to notice. At least that's what it sounds like.
Old 02-16-2007, 11:41 AM
GTP Dad GTP Dad is offline
Pontiac Guy
I have to agree with Hotbug1776. You have a leaking heater core. Some of the signs are fogging windows when you turn the heat on or a strong antifreeze smell in the interior. A small leak is hard to detect. Stop leak is not a good idea and may make matters worse. The only sure way to eliminate the issue is to replace the core assembly.
Welcome to AF!!
Old 02-17-2007, 01:03 AM
hotbug1776's Avatar
Agreed on the stop leak...bad stuff, fills the hole but also fills the radiator and coolant passages as well as runs through your water pump.
I've never taken out the core in a sunfire, but it doesn't look like its a huge undertaking. A days work in a warm garage.
