Old 02-15-2007, 12:00 PM
bonethugs bonethugs is offline
Compatability???
I am wanting to put a 3800 in my cavalier z24 with a 5-speed manual. I'm wondering if the stock transmission will work??
Old 02-15-2007, 12:13 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: Compatability???
no...also the 3800 sucks....do something worthwhile. I had a 2003 Bonneville SLE and that thing was completely gutless...for the money, you could turbo/supercharge your stock engine and make more power
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 02-15-2007, 03:29 PM
dwb985 dwb985 is offline
2000+ Getrag 2.2 5 speeds will work but you need a Camaro flywheel and it needs to be machined. you will also need HP Tuners or send it to Digital Horsepower and they will tune the PCM for you so the PCM knows it not an auto anymore because they only came in autos. building up a V6 will always beat building up a 4 banger. even when it comes to money because you will rebuild the 4 banger alot quicker than the V6 and theres no replacement for displacement.
Old 02-16-2007, 03:29 PM
Lances133's Avatar
Lances133 Lances133 is offline
Send a message via AIM to Lances133
Look up SHOoff on www.clubcav.com
Old 02-16-2007, 05:30 PM
Schister66's Avatar
AF -Advisor
not necessarily and i really doubt he's going to get to the point where displacement is going to make a big difference. The fact is, the 3800 is a piece of crap engine that would give you minimal improvements over the stock 4 cylinder for a few thousand dollars. You could easily build a cheap little turbo setup and see a lot better gains and spend less money. In the end, yes, it will come down to displacement, but i see it as one or the other...either he swaps in the 3800 or he boosts the stock engine....dollar for dollar, building the 4 is a better choice.
The reason i'm so against the 3800 is because in our 2003 Bonneville (which we sold in lieu of an 07 Mazda 6 Gran Touring) was a gutless piece....that and it had no resale value which really pisses me off....
Old 02-16-2007, 06:45 PM
millrtime millrtime is offline
i dunno about 3800's being completely "gutless" i have seen them hang with some pretty quick cars, granted they had some work done. couldnt think of any other gm v6 to put in there that doesnt cost out the ass....and will a getrag 5 speed really be able to handle the power? always seemed like a pretty weak tranny in my book
Old 02-16-2007, 11:19 PM
see your problem is your thinking its gonna be like the Bonneville and the Cavaliars are nowhere close to them in the weight. there's a video of a Cavi with the 3800 swap done and it squeals the tires even in 3rd and not going full throttle (when the video was made he was still breaking in the motor). i have also seen a video of a 2.4 turbo charged that even squealed the tires in 3rd but i think i remember him saying he had to rebuild his motor already which as far as i know Raven hasn't had too.
to be totally honest its all about the personally preference. if he prefers to do the swap you shouldn't stop him instead explain all thats needed and if you don't know then let it go. i think after he reads all that has to be done he'll give up. then again you can buy most everything you need including the engine cradle. yes it needs a new engine cradle you have to gut the entire front end.
and finally yes the 2.2 Getrag can take the power there are many of them being used on the L67 version of the 3800. but theres really no reason to use it (unless you just like going through the gears) because auto's are better for drag racing and manual's are better for track racing. if you think you can go around a track with all that weight up front you are dead wrong its gonna push like crazy but the weight is good for drag racing because extra weight on the front tires will help it hook up better.
Old 02-17-2007, 12:09 PM
Schister66's Avatar
AF -Advisor
a 3.8L that makes 215bhp and 200btq is not exactly fast....my 1.8L makes over 300bhp and about 225btq. I can make a 4 faster than a 6.....wait til this spring too.
Also, what is the weight difference between the two. I cant imagine that beast 3800 is light.
Cost vs benefit
Boosting the 4cyl is going to be better than the swapped 6cyl
Old 02-17-2007, 03:02 PM
first off your comparing a no power adder, untuned engine to a tuned turbocharged engine theres no chance for it. 2nd i'm not talking about the L32 motor you had in the car you had i'm talking about the L67 (which if he's talking about the L32 then its not worth it at all the L67 is the way to go even if you prefer a turbo). 3rd you can build alot more horsepower into a V6 than a four banger and you can build alot more into a V8 then a V6 its just a fact more cylinders more power plus you add more reliability (provided you don't dog it everywhere no matter the engine you dog it long enough its gonna pop). and finally more horsepower always costs more money fact of life.
Edit: i forgot about the weight thing the cars the L67 come in weigh in at around 3800 pounds a 97 Z24 (i used my car) weighs in around 2800 pounds and you have to take out the weight of the engine.
Old 02-17-2007, 03:49 PM
Schister66's Avatar
AF -Advisor
the thing you keep overlooking is that he has a set amount of money...you're going to have to pay for the swap AND THEN add more money to make it faster.
The way i see it, he has 2 options. Either build/boost the 4 or swap in a STOCK 6. What do you think is a better option in that instance. I agree with you, if he was to have an unlimited budget, then yes, i would agree with the 6, but seeing as that's not the case, i'm thinking practically
Old 02-17-2007, 03:56 PM
SwiftyR SwiftyR is offline
Send a message via AIM to SwiftyR
well a tuned 4 cyl will of course be more powerful then a untuned V6...
the 3800 supercharged motors in the Monte carlos in my opinion have some balls... droppng that into a Cav would be sick...not to mention the bigger motor will be able to handle more boost and whatever else you add to it...
Old 02-17-2007, 04:28 PM
Schister66's Avatar
AF -Advisor
you know what...you guys know my opinion on this and if you want to make a stupid decision and fight with a swap, then spend more money on something else to make it fast....go right ahead. I dont really care. I'm more or less trying to offer another solution to the problem. I dont think it is smart to waste a few thousand dollars on a swap that is going to give you minimal gains. Yes, it would be a fun swap, but then again, you could do things to the stock engine that would make it as much fun, if not more fun than the V6 for the same amount of money.
Have fun and do what you want...
Old 02-18-2007, 09:14 AM
Thanks for all the suggestions I think I will stick with the 4 afterall... Just to much work with the 6
Old 02-18-2007, 10:52 AM
Lances133's Avatar
I still say contact SHOoff and show him this thread.
Old 02-18-2007, 07:01 PM
Derk_eliso's Avatar
Derk_eliso Derk_eliso is offline
Send a message via AIM to Derk_eliso Send a message via MSN to Derk_eliso Send a message via Yahoo to Derk_eliso
Originally Posted by Schister66
...I dont think it is smart to waste a few thousand dollars on a swap that is going to give you minimal gains. Yes, it would be a fun swap, but then again, you could do things to the stock engine that would make it as much fun, if not more fun than the V6 for the same amount of money.
It would cost him more to soup up his 4 cyl then to do the swap... depends on his plans after the swap, if he was going to turbo/super charge it... the swap will be better then his current 2.4, but it wouldn't compare to your turbo'd go kart motor...
