Old 02-15-2007, 11:39 AM
cizzi05 cizzi05 is offline
blower motor
blower motor when on the med through high settings vibrate the whole dash board what could be cuasing this problem
Old 02-15-2007, 11:52 AM
Scrapper Scrapper is offline
AF Premium User
Question Re: blower motor
blower should not make motor shake but a tranny or motor mount might.
Old 02-16-2007, 02:18 PM
panzer dragoon panzer dragoon is offline
Re: blower motor
if the fan is cracked your motor will be unbalanced and you will have vibration. Maybe ice build up on the fan = condensation problems (typical Intrigue problem). Ice could have also cracked something.
how do you make an electrical vibrator = a unbalanced electrical motor.
Run the fan on low until you notice good heat coming out of the vent - if the vibration goes away = ice build-up on the fan = you have a condensation problem.
Usually it's just corroded/ungreased bearings/shaft that make excessive noise and squeeks. =Eventually you blow out those controller resistors and lose fan speeds. The lowest fan setting on my Intrigue does not work.
Old 02-18-2007, 07:20 AM
Jimmy Olsen Jimmy Olsen is offline
Re: blower motor
You can look at the blower motor in operation by following the instructions for changing the cabin air filter.
