Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-15-2007, 03:27 AM
uchihajd uchihajd is offline
It wont start at all!
i have a 92 eagle talon that i just bought, the guy said its perfectly fine. The truth was it has a broken head gasket. Anyways, i was able to drive it and didnt find out it has a broken head gasket cause i couldnt tell until later on. i put a brand new after market steering wheel and turbo timer ( i think i mess up putting the turbo timer becuase when i was putting the battery it sparks out of no where, the turbo timer wasn't grounded btw). So when i got everything on right, the car wont start. I check the battery/alternator and they said it was good. so i put it back and still wont start. light is working fine except when i put the key on the ignition and turn it, there's no light comes out on the dash board and when i turn it all the way to start the car, it does totally nothing!. not even a click. so im thinking im mess up the ecu when i put the turbo timer without the ground on the first try, u think its the ecu or maybe the head gasket acting up? ( oh i change the spark plug/spark plug wires) PLS HELP!
Old 02-15-2007, 12:30 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: It wont start at all!
Check all of the fuses. You probably blew the ignition control fuse.
95 Talon TSI AWD
97 Eclipse GST
Old 02-16-2007, 01:51 PM
Adam_rex Adam_rex is offline
yep. check your fuses under the hood. your prolly opped an engine fuse in there.
1993 Nissan 240sx
1992 Nissan 240SX SE
--Parts Car--
1992 Camaro Z28
--blown up--
--getting 350 put in--
1993 Honda civic Del sol
--B16A swap--
--1997 jdm front bumper--
--1997 jdm fenders--
--Upgraded internals--
Old 02-16-2007, 03:55 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Engine fuse? If your going to echo a response, atleast make it seem like you know what your talking about. There are fuses to certain electrical components in the engine bay, not a fuse that controls the engine.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 02-20-2007, 11:38 AM
ok i feel stupid now. I checked all the fuses except those 4 fuses. So yah your right, it was the ignition fuse and the battery was low. I went to kragen to charge the battery and few days later i installed it with a new use ignition fuse ( i know it works cause i swap it with my 90 plymouth laser. Still... it wont start. When i turn the key half way the light's work fine and when i turned it all the way to start the car and still nothing happen, it wont even try to start. Few try later.... i turn the key half way and the lights on the dash board is gone! no freaking lights at all! and when i start it nothing but my fart that i could hear! so im thinking swapping the ecu when i have time.
Old 02-20-2007, 09:07 PM
Are the battery connections good? Sounds like you may have a loose connection.
95 Talon TSI AWD
97 Eclipse GST
Old 02-22-2007, 02:58 AM
Talking Re: It wont start at all!
My brother said perhaps its the battery so im gonna try to buy a brand new battery since that one is an old one and i dont know how long its been since i just bought the car couple months ago. And yes, the battery and the connector are secured and tight. Im gonna install it early tomorrow morning! *wish me luck!*
Old 02-22-2007, 09:35 AM
Get it tested first before you go out and buy a new one.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 02-22-2007, 09:44 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
I would be cracking open the ECU and make sure you didn't burn up any of the traces. You also want to take a really good look at the caps while you are in there. They almost always leak on 1g's and need to be replaced before the leak on the board. Look for them to be swollen or leaking.
Even if they aren't leaking, I would still send out the ECU and have the caps replaced. It's not too expensive and can save you an ECU down the road.
Oh, and here is a good diagnosis write up for no start issues:
http://www.dsmtuners.com/forums/show...ght=ecu+sparks
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
