Old 02-15-2007, 12:05 AM
Phix_06 Phix_06 is offline
02 Accord will not shift out of Park
I have an 02 Accord LX and am having all kinds of trouble with getting it out of park. I have to mess around with the break several time beofre it will release. Any Help on this matter will be greatly appreciated.
Thanks,
Dave
Old 02-15-2007, 12:13 AM
mpumas mpumas is offline
Re: 02 Accord will not shift out of Park
Is the P light lit on the dashboard when you are having problems getting it out of park? Do you hear a clicking sound when you press on the brake petal when the car is in park?
Old 02-15-2007, 08:41 AM
cdc692003 cdc692003 is offline
park neutral safety switch is most likely bad
Old 02-15-2007, 03:28 PM
Yes the park light is lit. The only time that I hear the click when I apply the brake it shifts out of park. I was guessing in the ballpark of CDC's reply. Is this something that is easy to fix or will a dealership have to repair this? Thanks for the replies!
Old 02-15-2007, 06:46 PM
Ok I lied!! When the problem occures the break lights do not work either. What does this mean??????
Old 02-15-2007, 09:33 PM
Probably a broken brake light switch. That switch powers the brake lights and the shifter interlock relay plus the cruise control disengage circuit. Easy to replace if you can fit on your back between the firewall and seat
Old 02-18-2007, 01:17 PM
NesOne NesOne is offline
I just experienced the same problem and fixed it yesterday, it is the stop switch that is located right above your brake pedal. I called the dealership parts dept. and it was $35. Once I put in the new one, my brake lights starting working as well, but before that my brake light bulb was burned out, so if your brake lights still don't work, check that bulb. It cost about $7 at AutoZone, part number was 7440, forgot the brand though, lightning something. Good luck.
Life's a Joke, and... Death is the Punchline
