Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 02-14-2007, 10:02 PM
DUB_LS619 DUB_LS619 is offline
NEED HELP with my zex wet kit
i hooked up my wet kit and for some reason the brain does not wanna learn the tps...and yes it is the right TPD cuz i did a volt test on it...someone told me i need the 05 mustng wet kit...someone else told me i need the resistor wire..does anyone have any ideas about this matter??
Old 02-15-2007, 07:01 AM
Quik_LS's Avatar
Quik_LS Quik_LS is offline
Send a message via MSN to Quik_LS
Re: NEED HELP with my zex wet kit
there is nothing unique about the LS TPS - 0-5v, I swapped mine with a 99 3.8L mustang TPS as part of my supercharger project - the LS PCM doesn't care as long as it's the right connector and mount is proper.
If you purchase a kit for the new mustang - I believe is comes with a fuel rail adapter - that makes tapping into the fuel line a snap - only problem is that it does not fit the LS fuel rail.
There has to be another problem - the TPS should be fine. The ZEX kit can be real picky about the electrical connection - so if the slightest vibration is shaking the connection - it may reset it....
Quik LS - Austin, TX
more, more, more.....
#0018 ESP SCCA solo2
LLSOC.com - President
see my mean LS
see my Lotus Esprit - Quiker
