Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-14-2007, 08:31 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Clutch... DAMN IT!
ok, so i hop in my car after its been sitting at my parents house for about a month, and i fire it up. Starts like a champ, and everything is great (as usual ) anyway, i go to back out of the garage and the clutch peddle drops to the floor, so i pump it a few times, and clutch peddle regains "firmness" and i pull out of the garage, and pop the hood... Clutch Fluid level was good, so i figured it must have gotten a bubble or to in the line since it sat for so long. well, i get down the driveway, and take it out or reverse, and get out. (had to run inside to get my cell phone) and i come back, and go to put the car in first, Peddle is soft again! so i pumped it up, i was kinda concerned at this point. So after pumping the clutch a few times, it regains pressure, and i started down the road, i had trouble getting into second, had to "double clutch" *kick the peddle twice* to get into second, so i turned around and went back home. double clutching again to put the car in first, and i pulled back into the driveway. i immediately thought, Master cylinder, however, their is very little clutch fluid on the floor board, just bairly enough to feel just above the 4th peddle (foot rest) so is it possible that the lines just need to be bled again? or do i infact need a new master cylinder? car has 55XXX miles, stock clutch, stock lines, dot3 redline fluid, mods in sig. thanks guys!
Old 02-14-2007, 09:00 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Clutch... DAMN IT!
Try bleading the lines, and if taht doesn't work, then try the master cylinder. Did you look at the slave cylinder at all?
95 Talon TSI AWD
97 Eclipse GST
Old 02-14-2007, 09:03 PM
Black99GST's Avatar
no, i didnt have time to really look in depth, i was taking the car to an appointment, but since it wasnt in "running" order, i had to take the beater....
Old 02-14-2007, 10:22 PM
Killa's Avatar
Killa Killa is offline
Master cyclinder.
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 02-14-2007, 10:29 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Nothing is supposed to be leaking... I vote master cylinder...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 02-14-2007, 10:36 PM
Black99GST's Avatar
any suggestions on where to pick up a master cylinder? (i'mma check to make sure first, just kinda wanna know the damage before hand...*$$$*)
Old 02-14-2007, 10:40 PM
Killa's Avatar
Well it will leak fluid until it dry up, and the clutch will stay to the floor all the time, if your floor mat is wet, im 100% sure its was master cyclinder, I been there . and I bet most people here did too.
GM FOR LIFE !!
95 camaro lt1
Old 02-14-2007, 10:54 PM
Autozone would be your best bet...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 02-14-2007, 10:56 PM
Killa's Avatar
,$80-$90
GM FOR LIFE !!
95 camaro lt1
Old 02-14-2007, 11:15 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
It's usually the slave cylinder that goes.
now - 2000 civic
soon - 2002 is300
Old 02-15-2007, 05:01 PM
Black99GST's Avatar
Originally Posted by Killa
,$80-$90
GOD DAMN! i dont have $80!!!
Anyone have an estimate on the cost of a slave cylinder?
i hope it just needs to be re-bled!
Old 02-15-2007, 07:40 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
If you have fluid in the cabin then it would be Master Cylinder...I think I only paid like $60 for mine...I went to Autozone...
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 02-15-2007, 08:34 PM
Slave cylinder is like 50 new...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 02-15-2007, 08:40 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Quoted for the truth. Exact same thing happened to my buddies Del Sol, both of my dad's trucks, and my other buddies RX7. Actually, I bet you have two problems, the slave and the master. I dont think the master should be leaking any shit, but the lack of pressure except when you pump it is probably due to the slave cylinder.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 02-15-2007, 08:52 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Speaking from experience my car basicly did the same thing, and I replaced the slave cylinder and bled it and all was good.
1991 GSX 2.3 Stroker
