Old 02-14-2007, 09:22 PM
79Bandit's Avatar
79Bandit 79Bandit is offline
Dumb question? IDK
if i have a crank that has already been balanced and i buy new pistons and connecting rods do i have to get the crank i have rebalanced or am i a dummy could someone explain what a machine shop does when you pay them to balance something? thanks-
Old 02-15-2007, 02:57 AM
Morley Morley is offline
Re: Dumb question? IDK
To balance and engine the entire rotating assembly (pistons, crank, rods) need to balanced together as a set. The rods are weight matched as are the pistons. There are places on the rods and pistons where they can remove metal to get them all to weigh the same.
And no, it wasn't a dumb question.
Old 02-15-2007, 03:06 AM
79Bandit's Avatar
hey man thanks for the reply so does this mean if the crank is already balanced then i need to have it rebalanced with the new set up or that all i need to have balanced are the pistons and rods?
Old 02-15-2007, 03:16 AM
goldz28's Avatar
goldz28 goldz28 is offline
You will have to have all of the parts together balanced.
I love wikipedia, here is a link, click me
2008 G8 GT ~ 2004 Silverado LT ~ 1998 z-28
Tuned By TJ Wong - Wong's Performance Engineering
Old 02-15-2007, 02:45 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
personally id have it rebalanced,anytime you add anythign to the rotating assembly i think it should be rebalanced even if the pistons and rods are weight matched
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 02-15-2007, 09:48 PM
Earlsfat's Avatar
Earlsfat Earlsfat is offline
Cheesesteakoholic
To include replacing a bad piston??? ANYTHING? Or are you talking on a rebuild and replacing entire sets of stuff... rods, pistons, etc? Doesn't include a new cam does it?
Cheesesteak..... It does a body good.
"All you want to talk about is money, let's talk about love, and sex... forget love, let's just talk about sex. "
Old 02-15-2007, 10:04 PM
1986Z28's Avatar
Has a Camaro
personally if your replacing one piston it probaly wouldnt be a bad idea to replace em all and do rings, and yes i think it should be balanced, usually around 150$ for the machine shop to do it too
Old 02-16-2007, 02:43 AM
Replacing a bad piston shouldn't be a problem as long as you had written down the weights of all of the pistons and their locations so you can be sure of getting the right weight in the right place (this is a non race engine, for a race engine then rebalance it all). If you were replacing even a single rod, then yes, rebalance the entire rotating assembly.
No, the cam isn't included, just the rotating assembly, which consists of: crank, rods, pistons, flexplate/flywheel and harmonic balancer. The higher performance the engine the more critical it is to have all parts balanced together. On a "hot" street engine you could get away with replacing a harmonic balancer or a flexplate/fly wheel or a single piston without rebalancing. But if I were pushing over 500 HP from the engine, I would rebalance for any single part replacement of the rotating assembly.
