Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 02-14-2007, 07:17 PM
gmcman02 gmcman02 is offline
1998 Jimmy radio flashing
Well, I got reallhy impatient one night while installing a new radio and i cut the factory wiring harness. i re-hooked it up but when i put the car in gear and hit the gas the radio completely turns off. when i stop again it turns back on. should i replace the entire dash harness? if so what is the exact name for the harness? if not any other help would be much appreciated. thanks
Old 02-15-2007, 02:46 AM
error_505's Avatar
error_505 error_505 is offline
Send a message via Yahoo to error_505
Re: 1998 Jimmy radio flashing
Just a shot in the dark here..... have you by any chance checked to see if your ground wire on your radio is secure? The changing of positions when in gear may move the wire a bit and not make a connection. Just a thought. Good Luck!!
Thanks,
Andy
Jack of all Trades......Master of None
__________________________________________
1998 GMC Jimmy V-6 4.3L
1998 Dodge Neon 2.0L DOHC
2005 Pontiac Gran Prix V-6 3.8L
Old 02-22-2007, 11:05 PM
i did and it is secure i eventried it with my stock radio in and it still does the same thing. right nw i have a toggle switch from the cars constent wire(yellow) to the radios constent wire and power wire. and that work but i have to reset everything everytime my car is turned off. thanks
Old 02-23-2007, 02:00 AM
error_505's Avatar
Why not put your RED wire on a switch and leave the yellow wire(constant hot) plugged up so you will have memory. If you still have the factory connector, why not just splice all the wires back together. Good Luck.
Thanks,
Andy
