Go Back   Automotive Forums Car Chat > Geo > Tracker
Old 02-14-2007, 04:28 PM
igya igya is offline
Timing Belt Change Made Easier!
The biggest hassel I found changing timing belts is getting the fan nuts loose and removing the shroude with the pulley. I have taken a cutter and removed a LOT of the plastic from the top of the shroud. Now, I can easily get to the fan nuts and remove the fan & pulley BEFORE removing the shroud. No more bloody knuckles! And, it does not any hotter even on 100 degree days. Try it, you'll like it!
Old 08-30-2007, 04:51 PM
Re: Timing Belt Change Made Easier!
Been there, done that! I've done that to 3 Trackers and it allows me to change a belt in less then 2 hours. Absolutely no change in running temps even in July and August!
