Help: Heat stopped working
Hi all, just had a call from my mother whose heat has stopped working in her car. She said that it is still blowing plenty of air but it's ice cold and it just started happening today.
She told me that there is a funny smell coming from the car so my first thought is heater core, but she said it is not sweet smelling and there are no leaks inside or outside the car. Any ideas? Car is a 1999 Plymouth Breeze with 100,000KM.
Daily: 2010 Dodge Ram Laramie 4x4 5.7L HEMI Others: 1996 Grand Am SE, 1998 Grand Prix SE |
Re: Help: Heat stopped working
blend door in the HVAC box could be stuck or broken,
or its cable might not be moving the door the cable could have come off the heater control unit in the dash later is most likely pull the control unit and look to see if the cable is still on the lever and moving the cable if there is not resistance to the lever or the cable then it probably came off at the door shaft in the box assembly today i am working on a 99 breeze it has no heat at all from the heater the hoses are warm to and from the core, the lower rad hose was cold, the upper was as hot as the engine, i put a new thermostat in it and the lower got warm but not hot, still no heat inside the car at all, so we are going to go ahead and pull the core out and replace it has to be plugged up doesnt make sense that both hoses are arm, but many things dont make sense in this life the old original chrysler 70k miles old thermostat was worn badly however, very easy replacement, the easiest one i have ever replaced, no gasket, no sealer, no anything, its awesome ![]() 2.4L engine that is replacing the core isnt that bad really, you do have to unbolt the entire dash and remove the shift knob and console, but its just a matter of some screws and bolts not that bad, straightforward remove the radio and HVAc controls bezel, and the dash end cap covers, they all pop on, just pry them off carefully, no screws on them pull the shift knob and console remove the underdash panels, round clips to pry out unbolt dash, lift up and away some to get to the core cover pull the core now the opposite order will tackle that tomorrow
I also am user fastr68 here- Randy -'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee, Last edited by randy78; 11-17-2007 at 08:37 PM. |
