Old 10-02-2002, 06:37 AM
gimmezell gimmezell is offline
Cam Gear Qustion
Soon I will be getting a AEM Cam Gear for my D16Y8. My question is should I leave off the cover on or cut the top portion of the timing belt cover? Any ideas?
Thanks,
Jeremy
Old 10-02-2002, 07:15 AM
sparq's Avatar
sparq sparq is offline
AF Premium User
Send a message via AIM to sparq
Why?
AF's Official Asshole
RIP AUNIE
Old 10-02-2002, 08:30 AM
luti luti is offline
Send a message via AIM to luti
Obviously you've never looked closely at your engine. The timing belt cover is 2 pieces, and the way it mates to the valve cover, if you don't reinstall the the top side cover the cam gear is left perfectly exposed. Thats what I did on my car.
T3/T04E turbocharged ricer.
Old 10-02-2002, 08:37 AM
Did not know that, thanks for the info.
Old 10-03-2002, 11:20 AM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
I would reinstall the top cover for normal driving , if something fel down in the thier kiss your t. belt bye bye.Not that it would be easy to fall in there but theres a small chance something could.What i did was trim the lip that fits under your valve cover so just the 2 bolts hold that timing cover on, then you can change your timing but not leave that hole open 24/7
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 10-06-2002, 05:09 PM
91civicDXdude's Avatar
you shouldnt get a cam gear unless you have an aftermarket cam. It really has no purpose except to look cool. since the y8 is a single cam, if you advance the cam timing, you are advancing both the intake and exhaust and that is not a good thing. a cam gear is used to dial in the exact timing of the cam if you buy an aftermarket one because they are usually like 1/2 tooth off.
is A6 cam-gear & Z6 cam-gear the same?? QuikShifter '88 - '91 Civic | CRX | Wagon | Shuttlee 8 04-12-2004 06:19 PM
cam shaft and cam gears in b16a GENONCARL Engineering/ Technical 1 03-28-2003 11:36 AM
Cams or Cam Gears bcsintegra Engineering/ Technical 18 02-05-2003 08:54 AM
cams & cam gear installation $$$??? KEiTHo Integra 0 02-26-2002 07:22 PM
