Will the A/C run in cold weather ?
Hi I have a problem with my 2006 A/C. I am testing it before a trip to florida but it will not run. The A/C will turn on and run if the car is in the garage or if I allow the car to run with out driving it. As soon as I drive the indictator light flashes and goes off. If I try to turn it on again the light flashes and turns off. Is it possable that the A/C will not run if it is too cold, It is about 5 degrees in NY now. I am thinking that with the car running the engine compartment warms up and allows the A/C to run but when I drive it gets cold under the hood and shuts off the A/C. I have talked to the dealer but they don't seem to understand the problem. Thanks in advance.
Re: Will the A/C run in cold weather ?
It has to be above a certain temperature outside for your a/c system to operate. I believe it's over 45 degrees, or around there. I always try to run my a/c during the winter months when we get a warm spell,( I'm in NY also and it's 9 degrees now
). I usually have to wait until the outside temp is at least 50 for it to get cold and operate. It is a good practice to run your system occasionally weather permitting in the winter if you live in colder regions.EDIT: Is there reason to believe your a/c may not work once you get into warmer areas? How did your system operate prior to winter? I'm going to Florida with my family next week and I am driving my 2006 Uplander. My system worked well into early January as I kept checking it whenever it was warm enough to do so. Chances are your system is fine as it is relatively new.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. ![]() If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
I recall it was 40 degrees F for previous generation Impalas including defrost mode. For later not sure but there should be an annotation in the Chapter of the owner's manual that covers your HVAC/climate control.
interesting thread, I noticed my Grand Ams A/C would not work very well when it is cold but during the summer it'll freeze me out of the car.
master airframe mech/shadetree auto mech/30+ years experience current vehicles: '02 Impala LS 3.8L '02 Trans Am WS6 LS1 6spd '99 Grand Am SE 3.4L '71 Cutlass SX 455/TH400 '04 YZ450F '07 Kona Garbonzo (dowwnhill mountain bike) |
. I can see just how much worse the buildup would be if it could run at these low temps.
I always thought the A/C ran intermittently when ever the heat was on. No matter what temp. It was supposed to remove moisture. Turn on the heat and watch the clutch on the compressor cycle every now and then.
You guys have fun testing the theory that it won't run in cold weather. I"M BUSY on that one!! Anyway, I know it's Florida, but it isn't THAT warm right now is it? It's February for cryin' out loud. I can't imagine it being over 70.
![]() This ain't your grandma's car!!
#2 I didn't ask if you thought I need the a/c #3 I go to Florida every year in February and it allways gets over 80 and sometimes close to 90 where I vacation. |
I didn't realize that it stayed that warm in Florida year round....I think it's time for a vacation...I wanna go to FL . good luck with your A/C
It is operating as designed. On GM vehicles, the computer controls A/C operation. The computer will not turn on the A/C compressor when the outside temp sensor reads about 40 degrees.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again? Got all the certifications 25 years ASE Certified Master Technician GM WCT Yea..I work at a DEALERSHIP....got a problem with that? Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality) This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video PM Me for details |
