Old 02-14-2007, 08:32 AM
sawdust2 sawdust2 is offline
Front end whining
I have a 96 grand Prix with a 3.1 with 165,000 miles. I have noticed a whining coming from the front when I drive it. I seems at 40 mph it is the loudest. Then it seems to quiet down some at higer speeds, but never goes away. The noise does not change with the rpm"s. Could it be a bad bearing or a bad c/v shaft. How do I tell ?
Old 02-14-2007, 08:50 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Front end whining
Jack up the car and try to move the wheel in and out. If there is freeplay at all positions, then the hub is the problem. CV joints will normally make noise only when turning sharply (outer) or while driving down undulating roads that make the suspension compress and expand (inner).
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 02-14-2007, 05:47 PM
guitarfish's Avatar
guitarfish guitarfish is offline
If those are the original front wheel bearings, then it's a good bet they're worn. Like Rich said, jack it up. Put hands at 3 & 9 o'clock position on tire, push one hand in while pulling the other out, then vice-versa, back and forth. If it's worn, it will have a knock knock sound. Do the same with hands at 6 & 12 o'clock positions. If it's not worn, the wheel will be very firm and there won't be any play.
I've changed those things a dozen times or more through the years.
Current Grand Prix
2008 GP - 174,000
Former Grand Prix's
1994 GP SE - 231,000
1997 GP GT - 134,000
1998 GP GT - 225,000
2002 GP GT - 222,000
Old 02-15-2007, 10:59 AM
wethepplebmxer wethepplebmxer is offline
it prolyl only gets quieter at high speeds cuz the road nise gets louder...
The GTP's Kill list:
- 07 Impala SS
- 06 Cobalt SS S/C
- 00 Mustang GT
- 06 Charger R/T
- 90ish Prelude (modded)
- Eclipse GTS
- 03 or so Civic Si
- 96 Eclipse GS-T (some mods)
- 04 WRX (manuel)
- 94 Prelude V-tec (head, cat, more...)
- 06 WRX
- 96 T/A
- 05 300C
Mods: Thrasher CAI, 3.4 pulley, straight pipe (res and u-bend delete), ZZP PCM, Colder plugs, new wires, 180 t-stat.
