Old 02-14-2007, 01:20 AM
MunG35's Avatar
MunG35 MunG35 is offline
Send a message via AIM to MunG35 Send a message via Yahoo to MunG35
Frame Damage
Hey all,
Looking to buy a used 2003 Nissan Sentra SE-R
Frame Damage reported on the car but title is clear. Owner says it was hit in the right reat quarter. Only 37k on the clock.
How should I go about getting this car? Getting a good deal on the price!
Posted in Nissan thread... got mixed results...
What should I do to ensure the frame is properly aligned and if not, how hard is it to get back to manufacturer spec?
Also, once back to manufacturer spec, is it fair to assume that it will behave as a un-damaged frame would?
Thanks in advance.
Are stock tips worth anything? See how the experts do: http://www.stocktiptrader.com
Old 02-14-2007, 02:48 AM
chevcamaro_86 chevcamaro_86 is offline
Re: Frame Damage
wow how cheap. i really wouldnt recommend it im sure the car will never be the same no matter what the cost. as an example my uncle rolled his 05 envoy a little more dramatic than getting minorly hit but still screwed up the frame and it was covered by insurance fully so it has been sent in several times to be fixed and every time showing another problem. and it is not the same as before, my aunt and uncle bought the suv new and have had an actual gmc mechanic work on it while they had a loner envoy they really could tell the difference. just my opinion.
Old 02-14-2007, 02:49 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Frame Damage
Often, collision damage varies from one car to the next, so it's difficult to advise you on this specific case.
You can reduce the risk by taking it to a really good body shop, one that has the tools and equipment to straighten and repair unit body cars.
A good shop can measure the car at certain critical points to see exactly where the crash has distorted the structure. Often, the structure can be pulled into alignment, essentially by reversing the forces of the crash.
However, cars are structurally complex and its difficult or impossible to fully correct for all distorsions. Furthermore, straightened metal is permanently fatigued and 'work hardened' which may (but not always) produce future problems. It all depends on the severity of the initial impact.
IMO take the car to three body shops which have the equipment and expertise to do this kind of work. Call your insurance company and ask them which shops they recommend. Get an estimate for each and have a serious discussion with them on the cost of repair, the severeity and the expected results of any repair.
Any decent body shop is familiar with the financial implications of crash damage and should be able to give you an idea of the car's market value, as-is, so you know how much $$$ to offer.
Also, if you have any doubts, do not buy the car...... it's not worth the hassle unless you are sure of what you are getting into.
Old 02-14-2007, 02:51 AM
MunG35's Avatar
Re: Frame Damage
The laser inspections alone are $150-180 per shop... that's pretty steep to do 3 times...
Old 02-15-2007, 11:14 PM
KiwiBacon KiwiBacon is offline
Re: Frame Damage
It's always a tough call buying stuff that needs work.
Will the discount over buying a straight version of the car pay for all needed repairs?
If not, don't touch it.
Old 02-16-2007, 03:30 PM
UncleBob UncleBob is offline
AF -Advisor
Re: Frame Damage
its mainly a question of whether the damage is to bolt on components, or/and to the unibody. Bolt on components are very easy to replace. Damage to the unibody is very difficult to fix.
Also depends on the severity of damage. If the unibody is only slightly tweaked, then you very well might be able to adjust the alignment adjusters to compensate for it.
IMO, you don't need to go to a frame shop to know this, any shop with an alignment machine and a tech that knows how to use it could tell you how bad it is. But its going to be a crap shoot without more details.
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
