Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 02-13-2007, 11:52 PM
marnielee23 marnielee23 is offline
Send a message via AIM to marnielee23 Send a message via Yahoo to marnielee23
Question Turn signal problems
My turn signal turns on and off normally, the lights go on (both on dashboard and outside), however they don't blink. What could be the problem? It was happening before but I was able to turn off then on the engine and it would blink. Tonight I turned off then on the engine and it didn't blink. Please help! Thanks!
Old 02-15-2007, 03:05 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Turn signal problems
Both the turn signals and the hazard flashers work off the same flasher unit (it's part of the hazard lamp switch assembly). If your hazards flash, then your turnsignal switch is bad. If the hazards don't flash either, then the hazard switch is faulty.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 02-15-2007, 06:22 PM
crazy Jim's Avatar
crazy Jim crazy Jim is offline
...or maybe you have a coupla bulbs out...............
master airframe mech/shadetree auto mech/30+ years experience
current vehicles:
'02 Impala LS 3.8L
'02 Trans Am WS6 LS1 6spd
'99 Grand Am SE 3.4L
'71 Cutlass SX 455/TH400
'04 YZ450F
'07 Kona Garbonzo (dowwnhill mountain bike)
Old 02-16-2007, 10:38 PM
Cool Re: Turn signal problems
Thanks, guys! It's the switch, all the lights are working. Do you know how much it runs to fix the switch?
Old 02-17-2007, 08:44 AM
crazy Jim's Avatar
here is one for an '02 Impala (without center console) for 217$
http:////www.autozone.com/servlet/Ui...ole&PageSync=1
you never stated the year of your vehicle so I just searched for mine...
current vehicles:
'02 Impala LS 3.8L
'04 YZ450F
Old 02-18-2007, 05:34 PM
Talking Re: Turn signal problems
Thanks! Sorry, it's a 2003. So it's probably about the same.
Old 02-19-2007, 07:59 PM
danmeyer01 danmeyer01 is offline
I have intermittent turn signal problems in my 2001 Impala as well. I can get mine to start working everytime by momentarily turning on the emergency flashers. I suspect that indicates the flasher unit is defective. It usually only acts up when it's hot in the vehicle.
Old 03-03-2007, 11:19 AM
Iceman OIF 2 Iceman OIF 2 is offline
Hello, I just had this same problem with my turn signals working on and off. I figured out it was my flasher/Hazard button part because if they stopped working and I slapped the hazards on and jarred the unit then the turn signals would start working again.
Also you do not need to remove the dash to change this part. Simple take a flat head screw drive and pry the hazzad button off. This will break the old switch but it will expose the part so you can get it out. Take the same Medium size flat head and slide it next to the switch at the 4 o'clock position, take a needle nose and grab the switch in the middle. By pulling on the switch and wedging the screw driver between the dash and the switch you will be able to release one side of the switch from the dash. Now without letting go of the switch with the needle nose, take the screw driver and wedge it in at the 11 o'clock position. This will release the other side of the switch. Give it a pull and the whole thing will come out of the dash. Disconnect the wires via the plug being careful not to let the wires pull back into the dash and plug in new switch. Then simply slide switch in the opening and it will click into place, good as new!!
This is much easier than taking off the entire dash. It took me 20 minutes to figure this all out and do it on my car. If I did it again it wouldn't take me 5 minutes. hope this helps anyone with this problem.
As for the part, it is a direct GM part so there are no aftermarkets as for now. I went down to the dealer and bought it for $50 but you can get it cheaper through www.gmpartsdirect.com for $38 including shipping. The GM Part number is #10359031. Okay well Good Luck!
