Pistons Problems
Can anyone help me figure out where i can find pistons for my 68 pontiac 400ci i need pistons to fit a 4.15 bore and a 4.25 stroke i cant find them anywhere the only place i can think of is custom ross pistons but was in hope that someone knows something i dont thanks.
Re: Pistons Problems
summit normally has everything...
here's the only one I found: http://store.summitracing.com/partde...0&autoview=sku if you click thru the departments and parts by category it should take you to this page that shows it works with a 4.25in stroke. the parts spec page doesnt explicitly say it... http://store.summitracing.com/egnsea...115+4294774647 if you want something other than the dish piston that one is (to change compression ratio), I would try looking thru the catalogs at Napa or Autozone
90 Camaro RS V6 - swapped to V8 -350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft ESTIMATED 360-420 hp 380-430lb/ft torque
