Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 02-13-2007, 09:58 PM
my1967stang my1967stang is offline
Vacuum hose hornets nest
Whats the best way to replace all the vacuum lines under the intake manifold of a 93-95 RX-7? Is there any type of vacuum line to use thats better than others? I heard this job is a real pain to do.
Old 02-14-2007, 06:41 AM
72' Stang 351 H/O's Avatar
72' Stang 351 H/O 72' Stang 351 H/O is offline
Re: Vacuum hose hornets nest
I thought this was going to be how to kill hornets in a vaccum hose. As for hose. I would suggest rubber with metal mesh to make sure the line doesn't....suck in for lack of a better word.
Old 02-14-2007, 08:41 AM
jcsaleen's Avatar
jcsaleen jcsaleen is offline
32 solinoids....
Goodluck ~
"Driving a Mazda RX7 on the track for the first time was very cool ? this is a production car that most
resembles the movement of a formula car in my experience so far.
" ~ Igor
Old 02-15-2007, 10:38 AM
ghostrx7's Avatar
ghostrx7 ghostrx7 is offline
Send a message via AIM to ghostrx7 Send a message via Yahoo to ghostrx7
take your motor out, and get the new vacuum hoses that dont crack. you dont need a specific kit, just buy a long hose, and cut as needed...
88 10th anniversary rx7 and company h2.
[IMG][/IMG] [IMG]
atkins streetported 3mm seal engine, act clutch, lightweight flywheel, downpipe, straightpipe, greddy power extreme exhaust, hks ssqv blow off valve, short shifter, tein flex suspension, energy bushings, bonez intake, new brakes, rotors, toyo tires, mazdaspeed replica seats
Old 02-17-2007, 05:45 PM
drftk1d's Avatar
drftk1d drftk1d is offline
boost in, apex seals out
Send a message via AIM to drftk1d
you can get the hose techniqes one if you want a kit
RX-7 TII
Old 02-21-2007, 07:49 AM
ghostrx7's Avatar
thats what i got i think...
[IMG][/IMG] [IMG]
Old 04-22-2007, 11:53 PM
Tim McCreary Tim McCreary is offline
If money is not an object, use viton hose. Otherwise use silicone hose. NEVER use regular rubber hose as this is what caused the demise of the twin turbo motors to begin with (among other things).
Replace check valves with Viton check valves. Also, take the time to check the 12 solenoids end nipples to make sure they are not brittle. Press on them. If they break, then replace. The 7 or 8 that appear similar are acutally mechanically and pneumatically identical.
Tim
Old 04-23-2007, 04:21 PM
AcCordGeN5's Avatar
AcCordGeN5 AcCordGeN5 is offline
Send a message via AIM to AcCordGeN5 Send a message via MSN to AcCordGeN5 Send a message via Yahoo to AcCordGeN5
Tim
In addition, if you are going to be staying with the sequential system and want to maintain a 10-8-10 boost pattern (assuming your FD is in well running order). Do not forget to remove the 'restrictor pills' in your "wastegate" and "precontrol" actuator lines and insert them into your new hoses. It is a good idea to replace one hose at a time.
Good luck with the "rats nest". One weekend is all you need to complete this job.
Marc
Old 04-26-2007, 12:00 AM
http://www.usplastic.com/catalog/pro...ookie%5Ftest=1
Someone was selling these some time ago on ebay. They sure beat the stock check valves for quality and price.
Tim
Old 04-26-2007, 08:51 AM
AcCordGeN5's Avatar
Tim
Viton check valves are great. I am actually in the process of ordering a set from a member on the Rx7Club forum. Below is the link where you can order a set.
http://www.clubrx.org/default.asp?AC...=26&id=8&mnu=8
Tim,
What is the difference between the one you posted and the one Dale sells?
Marc
Old 04-26-2007, 09:25 AM
Originally Posted by AcCordGeN5
Tim,
Marc
Marc
As far as I know, just the price. They are most likely made by one company only.
Tim
Old 04-26-2007, 09:48 AM
AcCordGeN5's Avatar
Marc
Tim
That is what I thought. I just wanted to make sure there was no major difference. Better to be safe then sorry, you know how that is in the rotary world...lol
Marc
