Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 02-13-2007, 03:21 PM
Profg Profg is offline
A/C & Heat problem 1987 300ZX
I have a 1987 300ZX (non-turbo), and the heat does not work. The blower motor can be controlled, but non of the vent buttons seem to work, and I'm not sure if the temp control is working. Right now, I get only slightly warm air blowing from the windshield defrost vent. The fuses all seem to be good. I checked the relay cluster under the hood, and there is one missing that is labelled "Vacuum Pump". I'm not sure if there was ever one there, since I bought the car used. Any help would be appreciated!
Old 02-13-2007, 04:08 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
Re: A/C & Heat problem 1987 300ZX
try and find a relay for the vac pump... it's usually vacuum line issues that make the heat and a/c stuff not work... it's pretty ugly behind there so hopefully the relay fixes it
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
