Old 02-13-2007, 03:14 PM
dean1 dean1 is offline
'96 grand am se 2.4L hesitates at take off
I have a '96 grand am se 2.4L 5 speed. This seems to idle fine and above 45 mph it runs great. But at take off mainly in first and second gear it hesitates like it not getting gas. I changed the fuel filter, no difference. I changed the spark plugs and spark plug boots, ran fine for about 40 miles. I changed the alternator, ran fine for about 80 miles. I realize, by guess work, it could be a lot of different things. I would like narrow it down to maybe accouple thinks. Any one else had this problem? Thank you, Darrel.
'96 grand am 4 cyl. dohc 5 speed hesitates. Idles great, above 45mph runs great. When switching gears it acts like it not getting fuel. I change the fuel filter and that problem is not corrected. The check engine light sometimes comes on but not all the time. I have a lot of different people suggesting what it might be, the lastest one was the fuel pump. Any answers?
Old 02-13-2007, 05:02 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: '96 grand am se 2.4L hesitates at take off
Get your fuel pressure checked.
This will help narrow it down to the fuel pressure regulator and or possibly the fuel pump.
Also it could possibly be you ignition module.
And or your fuel injectors.
The ignition module can be tested to find out if its bad.
autozone and some other parts stores can probly test this for you for free.
1999 Grand Am SS 3.4 OHV
