Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 02-13-2007, 12:17 PM
mazdamx-6ls mazdamx-6ls is offline
Exclamation wont crank
my 99 Saturn sl2 sometimes wont start up. when i turn the key nothing happens. but when i try several time then it starts up perfectly, like theres was nothing wrong with it. is my starter bad? or is it a lose starter connection? or is it something else?
thank you for any help
Old 02-13-2007, 07:10 PM
Cat Fuzz Cat Fuzz is offline
Re: wont crank
Probably starter. Do you even hear a faint click? If so, replace the starter.
Old 02-17-2007, 04:20 PM
sickcallawayc12's Avatar
sickcallawayc12 sickcallawayc12 is offline
Re: wont crank
loose battery connection can cause similar outcomes like you described too. happened to mine and have seen it in others that needed the (-) tightened up a little more.
1998 Chevrolet Blazer LT (95% stock)
Pioneer AVH-P7500 DVD receiver
12" Alpine Type-R in a sealed box
PIAA Super Plasmas GT-X bulbs
PIAA Xtreme White bulbs
K & N drop-in filter
"Melo" and "AI". Enough said.
Old 02-18-2007, 04:06 PM
Re: wont crank
thank you for the input.
Yes it clicks but wont start. most of the time it starts up perfectly. i think after a longer run and faster speeds it clicks and wont crank. but given a little time and a few attempts it starts up again without any hesitation.
any further input will be appreciated.
Can somebody also tell me where the starter is located on this model?
thank you
Old 03-07-2007, 12:16 PM
silverado122775's Avatar
silverado122775 silverado122775 is offline
Re: wont crank
The starter is typically located under the car on the passenger side.
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
