Go Back   Automotive Forums Car Chat > Ford > E Series
E Series Forum covers questions and discussions regarding Ford E-150, Ford E-250, Ford E-350, and Ford E-450.
Old 02-13-2007, 11:38 AM
87dieselescort 87dieselescort is offline
wont start
alright i have a 95 E150 van with the 5.0 int it. yesterday i put in some subwoofers and so i had to disconnect the battery. the van ran good before but when i connected the battery back up and tried to start it, it wouldnt start. all it does now is is crank over and over. it has to be something with not getting spark or gas but im not sure. anyone have any ideas???
Old 02-14-2007, 08:13 PM
butch h butch h is offline
Re: wont start
You didn't break/disconnect small wire on the starter relay ,did you?
Old 02-18-2007, 09:35 PM
KimMG KimMG is offline
AF - Advisor
Re: wont start
Check all the fuses to make sure you didn't blow one when disconnecting and reconnecting the battery.
Old 03-28-2008, 04:37 PM
68ragtop 68ragtop is offline
Re: wont start
Do you find you problem? I have almost the same thing happening to a 93 5.8L Battery was dead for about 6 months Charged it & now I have no spark. Was running great before it was parked.
Old 04-16-2008, 09:01 PM
rhandwor rhandwor is offline
Re: wont start
If it has a distributor use a 12volt test light and check for voltage to the coil positive when trying to start. The put the connection on the coil negative it should flash if somebody is trying to start the vehicle. If it flashes take the module to Advance or Auto Zone and get it checked. If it doesn't flash replace the pickup in the distributor.
If it has a camshaft position sensor unplug it and use and ohm meter across the two terminals. It should go from zero to one if its good. Be very careful you don't get caught in the belt. You might have to remove the belt to check or make temp leads.
