A/C problem
My A/C only works when the switch is on high. It works perfect on high but the other settings don’t work. Everything seems to be working I just don’t get any air to come out in the low and medium settings. I changed the selector switch thinking it was bad and nothing changed. Any suggestions?
Re: A/C problem
There is a resistor array mounted on the evap housing under the hood. This resistor array controls the speeds that aren't high. There's a chance there's a problem here, more than likely the connector needs to be wiggled a bit.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
Re: A/C problem
Thanks for the response. Do you know if that is the same on a ’93? The picture looks like a late 80’s model and if I’m not mistaken mine has a different setup from the picture. I think the setup I have has to relay looking little boxes. Could that be it? Thanks again.
Re: A/C problem
You didn't tell us what the year of your car is and so I assumed - you know what happens when you assume ...
Re: A/C problem
That’s fine, at least now I have a starting point. Let's see if I can find it in my car. Thanks.
