Old 02-13-2007, 03:16 AM
thre3kgt thre3kgt is offline
few questions
hello...first of all, I have an exhaust leak and im not very familiar with what is what down there so i was wondering if anyone knew where I could find a diagram of the underside of a 1991 3000gt SL so I could find out where the leak is coming from exactly. Also all of my gauge lights dont work, speedometer, battery, oil pressure etc. I checked the fuses and their fine, if anyone has any insight as to how this could be fixed that would be awesome. Thanks a lot.
Old 02-13-2007, 04:41 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: few questions
Dash lights being out means taillights are out. Check the fuses under the hood. There is a fuse marked tail.
The exhaust is probably leaking at the flex pipe. The flex pipe is probably borke because you have worn motor mounts.
Old 02-15-2007, 02:37 AM
Re: few questions
well how can i be sure that is the flex pipe..and what is it that makes u say i have worn motor mounts?
Old 02-15-2007, 07:33 AM
Stealthee's Avatar
Re: few questions
Common problems
Old 02-15-2007, 03:50 PM
Re: few questions
so in regards to fixing the exhaust leak what would be the best way to go about it considering this is the second time in a few years that it has busted?
Old 02-15-2007, 05:27 PM
Stealthee's Avatar
Re: few questions
If its the second time then that definitely says worn morot mounts. Get new mounts and it wont happen again,.
