Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 02-12-2007, 10:33 PM
JayStnick JayStnick is offline
Window Problems
Guys one quick Question? I have a 95 Maxima all the power windows go down except for the one behind the passenger seat. Is it a sticky problem or a motor problem? Any suggestions?
Old 02-12-2007, 11:34 PM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: Window Problems
...may also be pinched/loose/wet wirin, low supply voltage to master module (oxidized connectors)
Check http://www.cardomain.com/ride/748507/13
Old 02-13-2007, 04:46 PM
Re: Window Problems
So basically just go ahead and take of the door panel off and see whats going on.
Do you think it might be off track?
Old 02-13-2007, 07:04 PM
slideways...'s Avatar
slideways... slideways... is offline
Re: Window Problems
could be off track, could be the regulator is binding, that happens alot on nissans. could be the motor.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 02-14-2007, 12:38 AM
Re: Window Problems
Never seen one off track... if u mean glass travel. To verify u have to open panel and and measure with dmm(or tester) the voltage applied to the motor... open motor connector. U may also give motor directly 12V and see how/if it moves or tries to move.
Old 02-14-2007, 12:48 AM
Re: Window Problems
Thanks guys!!
Old 02-14-2007, 12:54 AM
Re: Window Problems
If its the motor how much you think it will cost to replace.
Old 02-14-2007, 07:03 AM
Re: Window Problems
Internet shops seem to advertize new assy starting from 60$... (I've no experience) U may also ask from stealership, then select THE cheaper option =buy another maxima.
Heres one example
http://www.directauto.com/category-e...rch_year/1995/
