Old 02-12-2007, 09:53 PM
X2Xtreme360 X2Xtreme360 is offline
3000gt vibrates randomly
Every once in a while my car will vibrate. It doesn't really do it under any certain circumstances, it will do it for 5 minutes and then everything will be smooth again. It almost feels as if the tires were not alligned, it only does it at high speeds but like I said, not very often. (I'm sure it does it at lower speeds but it's more noticable at higher speeds.) Any ideas?
Old 02-12-2007, 11:11 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: 3000gt vibrates randomly
where does the vibration come from? can you be more specific?
you could always get your tires balanced. but before i suggest that, give us more details. it could be a loose part vibrating at that high speed.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 02-13-2007, 12:47 PM
Honestly, I can't think of any other way to explain it, lol. It's like a steering wheel vibration, but also in the gas pedal. My girlfriend can feel it in the passenger seat when it happens too, so I guess it all over. Just as it would do if the tires were inbalanced.
Old 02-13-2007, 06:40 PM
AutostradaVR4 AutostradaVR4 is offline
did you check for ice in the the inner "lip" of your wheels? happened to me once before.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 02-14-2007, 09:59 AM
Well it happens when theres no snow on the road. Plus if it were ice I would think it would happen all the time rather than on or off like it does. I dunno I'm stumped. Everything that I've ever driven vibrates either constantly, or never at all.
Old 02-14-2007, 02:56 PM
jeff983000gt's Avatar
jeff983000gt jeff983000gt is offline
have you checked you wheel bearings..cuz that happened to my once before and it turned out it was one of my rear wheel bearings..jack up your car and see if any of your tires have to much play in them..
Old 02-14-2007, 05:44 PM
Igovert500's Avatar
blue + red light magnet
cv joint?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
