Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 02-12-2007, 07:39 PM
suzymccoy suzymccoy is offline
OD problem with 86 Toyota
I have a 1986 Toyota Mini Motor Home, Automatic transmission with OD and a 22 RE engine. At a steady speed of 55 or 60 MPH, the OD kicks in and out. After doing that 4 or 5 times it kicks out and will not go back in. Does anybody have any suggestions? Thanks in advance from a newbie.
Old 02-13-2007, 09:24 PM
canadianbiz canadianbiz is offline
Re: OD problem with 86 Toyota
hey suzy, I am kinda new here too. I am sure some of the people here would have a better idea than me of what your OD problem is but I did read about a relay switch that could be a possibility.
Old 02-14-2007, 02:20 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Are you saying the OD no longer works at all, or after 5-6 in/outs it won't go back into OD until you drive it again?
At 60 MPH or so the OD should not be used (under most driving conditions), as evidenced by it's in/out behavior. The weight of the truck and that little 4 cyl engine just can't handle it. It's not good for the engine or transmission.
If it's totally non-functional it may be the OD solenoid in the tranny, or possiblly the trannies ECM.
When's the last time the tranny was serviced ? the fluid checked ? is there a tranny cooler ?
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
