Old 10-01-2002, 08:07 PM
Dallas_Fl Dallas_Fl is offline
Send a message via AIM to Dallas_Fl
For those that painted the interior
I was thinking about painting my interior, but I want it to be smooth like fiberglass. do I have to sand and primer for ever. and I also want to paint the vinal on my door, is this possiable?
Old 10-01-2002, 09:58 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Well, I think your best bet for a smooth finish is going to be alot of primer/sanding... Shouldn't take too much though. As far as vinyl goes, I know several people on this board have done it, but I have not. For all the plastic trim pieces, this is the process that I used, and it came out really well:
Materials/Tools required:
-- Primer.
-- Krylon Interior/Exterior paint
-- Clear Enamel
-- 320 grit sand-paper
-- Rubbing alcohol and Q-tips and/or cotton balls
-- Masking tape (also good to have masking tape with attached drop-cloth)
-- Various sockets/screw-drivers, etc. for removing pieces
A few words about technique/safety:
-- When spraying your primer, paint, or clear-coat, be sure to keep the tip of your finger out of the spray. Having your finger in the way will cause paint mist to build up on your fingertip, and the airflow will blow the built-up paint off your finger in the form of little droplets of paint. If these drops land on the piece you're working on, you might as well start over, cuz they look like crap. The same thing happens if you use a plastic pistol-grip attachment on your spray cans.
-- I can't say enough how important patience is. If you rush, you are going to make mistakes, and if you don't fix the mistakes (which is a huge hassle), you'll have a horrible looking interior. So it's best to just do it right the first time. Do whatever you can to avoid over-spraying the pieces. Personally, I smoked A LOT of cigarettes and drank A LOT of beer between applications, just to keep myself from using too much paint all at once.
-- I made the mistake of painting all my trim outside on my back deck. For some reason, bugs were really attracted to my paint and clear-coat, and kept landing on the pieces. They'd get stuck in the wet paint, and some of them are still visible in the finished pieces. If you have access to a well ventilated garage or paint-booth, I would highly recommend using it.
-- If you follow these steps, you'll end up with a durable, professional looking painted interior.
-- If you plan on painting your entire dash, or your gauge cluster cover, a really light color like white or bright yellow, be aware that on sunny days, it will be reflected onto your windshield, and in my opinion is a bit distracting, and can make it difficult to see sometimes.
-- Always spray paint in a well ventilated area.
-- This process is only meant to be used on plastic pieces. I have no experience painting vinyl-covered surfaces.
The Process:
Remove each piece that you want to paint (consult manual if unsure how to remove pieces).
Use the following process on each piece you want to paint:
-- Wash with soapy water to remove built-up dirt and grease.
-- Sand each surface you wish to paint with 320 grit sandpaper.
-- Swab each piece with rubbing alcohol to remove any left-over Armoral, finger grease, etc.
-- Wash again with soapy water to remove rubbing alcohol residue.
* at this point, be sure hold the pieces by the edges, or by surfaces that won't be visible. This is to avoid getting greasy finger-prints on the prepped surfaces.
-- Mask off any areas that you do not want to get paint on.
-- Apply 2 coats of primer. I used Rustoleum Primer.
* When I refer to "coats" I actually mean LOTS of really light applications of primer/paint. remember to take your time, spray a little bit, give it a few minutes, spray again, etc. Do whatever you have to in order to avoid soaking the pieces. You'll just get runs and sags like crazy.
-- Primer dries pretty quickly.
-- Once each coat dries, it's a good idea to lightly sand the primer with 320 grit paper. And sand after the 2nd coat as well.
-- After sanding each time, wash the piece again with soapy water to remove sanding dust.
-- Apply 3-4 coats of paint. I used Krylon Interior/Exterior paint from the local parts supply chain.
* Again, remember to take your time applying the paint. The Krylon takes a lot longer to dry than the primer does, so give it a bunch more time.
-- Once the paint has completely dried (I would give it at least 24 hours to be on the safe side), apply 2-3 coats of clear enamel. I used Rustoleum Crystal Clear Enamel for this.
* Same process as with the primer and paint steps.
-- Let the pieces dry again for at least 24 hours before handling. It's the most frustrating thing to spend all this time and energy on painting the pieces, only to put a fingerprint in them or scratch them with a screw-driver trying to install them while they're still a little soft. BE PATIENT!
When cleaning the painted surfaces, do not use Armoral (or similar products) or any kind of solvent. I've been using Simple Green, and it hasn't caused any problems, but someone else said they use Spray 9 and says it's good.
Old 10-01-2002, 10:50 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
I painted my stereo bezel and it came out pretty smooth, could have used a little bit more sanding, but if you use a lot of primer, and paint, and clear coat, it comes out really smooth.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 10-02-2002, 02:58 PM
fiercecivic's Avatar
fiercecivic fiercecivic is offline
Send a message via AIM to fiercecivic Send a message via MSN to fiercecivic
Yeh i painted my trim pieces and my speaker grills they all turned out SWEET and Smooth and i followed the steps that "ci5ic" gave to u. They are pretty smooth but im sure that u could get them smoother with more sanding and primer work!
Ok, for those that live in the cold... Ramblin Fever Rodeo | Passport | MU 14 10-24-2006 08:56 PM
For those that wanted the link to the Z06 Style Z28 Badges twdz28 Camaro Discussions 1 09-09-2004 10:30 PM
For those that don't like the new changes to AF: Setanta '88 - '91 Civic | CRX | Wagon | Shuttlee 16 08-19-2003 04:50 PM
For those that want to be the next Colin Mcrae tazdev COMPLETELY off-topic 2 08-09-2002 08:07 AM
