Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 02-12-2007, 06:59 PM
cubfan56 cubfan56 is offline
Speedometer sticks
This problem relates to an 03 XL with 41k miles.
The speedometer doesn't register the actual speed. It works when I accelerate but won't reset to zero when I stop (it sticks at approximately 20 MPH). When I start again, it takes off but has added 20 MPH to the speed. For example, I'll be actually going 35 MPH but the speedometer will read 55 MPH.
The problem is cumulative. When I stop again, it will add 40 MPH to the actual speed. It doesn't take too long and I'm doing 120 MPH while stopped at a light.
The only way to reset the speedometer is to repeatedly start and shut off the engine (It decreases the speed approximately 5 MPH with each cycle). Or, if I take the negative battery cable off and "arc" it across to the negative terminal.
My guess is that I have a grounding problem but I stink at automotive electrical issues. This happened once about 2 months ago and then reappeared this week and seems to be consistent.
Any thoughts from the list will be greatly appreciated.
Greg
Old 06-20-2007, 01:01 AM
gaspldr gaspldr is offline
Unhappy Re: Speedometer sticks
I had the same problem with my 2003 XL. Initially, I would turn my engine on and off to reset the speedometer to 0. It appeared to be temperature related, when cold outside, the speedometer would stick at 0. When hot, it would stick at 40 or above. Eventually the speedometer completely stopped working. I have heard many other owners complain of the same problem and paid $400 USD plus to have replaced. It sounds like a recall item!!!!!! Anyone know how to get this on the recall list?
Also having a problem with my driver side seat warmer...just stopped working but the passenger side works fine.
