Old 02-12-2007, 05:19 PM
thresher90 thresher90 is offline
Supercharger
Can you put the M90 supercharger (or the one that fits a 1997 Grandprix) on a 3.8L non supercahrged engine? Its all stock.
Old 02-12-2007, 06:12 PM
jeepgclwj's Avatar
jeepgclwj jeepgclwj is offline
Re: Supercharger
I am pretty sure you can but you will also have to change alot of other things as well. You cant just slap it on and go...
358rwhp/358rwtq with stock LS1 intake
A4 3.23 lid, pacesetter lts, ory, 243 heads, SLP LMI, ZO6 cam, BBK SSI intake, 85 mm
Old 02-13-2007, 07:59 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Supercharger
NO!!!
The 3.8 Non-SC is not equipped for the supercharger. The compression is too high and the transmission is not heavy duty. You would need a host of parts to do the conversion including a new fuel pump, PCM, transmission, axle shafts, injectors, fuel rail and others. I suggest you modify the normal 3.8 in other ways if you want the extra power. Or purchase a GTP!
Old 02-13-2007, 05:47 PM
Re: Supercharger
thanks for the tips
I'll look into a new exhaust and a CAI
Old 02-16-2007, 06:52 PM
MVGTP86 MVGTP86 is offline
Re: Supercharger
Originally Posted by GTP Dad
NO!!!
If you do a top end swap you can put an m-90 s/c on a N/A 3.8. You'll get more power out of an L36 because of the gearing...its a proven fact. But like GTP Dad said your better of buying a gtp, it will take a lot of money rebuliding the tranny and buying other parts needed for it. I would look into a turbo for an L36 (NA 3.8) you'll get a lot more power w/ a turbo.
2003 GTP - Brand New L67 crate engine, K&N FWI, Ported TB, 3.4 s/c pulley, Walbro 340 fuel pump, 180* T-stat, 1.9's, PEM'S, ZZP 3" Down Pipe, ZZP 1.0 PCM, gutted cat, u/bend - resonator delete, magnaflow mufflers and tips.
